Split Areas(Polygons convex and concave) by lines - Momentum curvature by fibers method - Messaggi
it's not so easy to do an algorithm. I did a smath file when the polygon it's rectangular but for more general case my smath code doesn't work, I'd like know an algorithm, code or function if it's posible in smath or other language to develop.
Jesus.
Verificacion_de_fluencia_en_acero_fiber_method_degradation_forum.pdf (550,67 KiB) scaricato 1185 volta(e).
Your polygon has 9 vertices, we can try a circular spline.
That will add as many points between vertices, is it ?
From there: Area, Perimeter, Center of Gravity.
Give the vertices... Jean.
polygon_2.sm (36,33 KiB) scaricato 1392 volta(e).
Jesus.
Page5 Polygon Copy.sm (116,59 KiB) scaricato 1647 volta(e).
Jesus.
WroteHi everyone ,I'm doing a momentum curvature usign Popovic's Method and found a big problem beacuse to divide a polygon(convex and concave) into small fiber like this image but with more lines:
Jesus.
This might be an application for the GPC wrapper plugin by Davide.
gpc1.sm (12,5 KiB) scaricato 1376 volta(e).
Jesús.
Jesus
polygon_irregular_fiber_borrador1.sm (34,31 KiB) scaricato 1412 volta(e).
polygon_regular_fiber_borrador1.sm (35,48 KiB) scaricato 1391 volta(e).
Jesus
InPoly.pdf (97,1 KiB) scaricato 831 volta(e).
InPoly.sm (43,3 KiB) scaricato 1360 volta(e).
Will we be able to calculate the static moment and the moment of inertia of any section with these tools?
Thanks a lot!
Has anyone worked on polyhedra, convex hulls and polar polyhedra?
WroteHas anyone worked on polyhedra, convex hulls and polar polyhedra?
I may have something on convex hull
Polyhedra, we have C_60 extracted from the adjacency matrix.
Handling the adjacency matrix is the only difficulty in fact. Polarity of points-planes is easy.
Wroteanything on the adjacency matrix I am super interested!
1. In the attached Buckyball, adjacency matrix is from Mathsoft,
Mathsoft borrowed fro Matlab.
2. I have the Mathcad convex hull ORIGIN 0
RemToDo ORIGIN 1 for Smath coding.
Buckyball Adjacency.sm (16,36 KiB) scaricato 1359 volta(e).
0Anim Buckyball.sm (107,29 KiB) scaricato 1357 volta(e).
Buckyball.sm (176,41 KiB) scaricato 1405 volta(e).
Wrotegpc3.sm (135,5 KiB) scaricato 1484 volta(e).
I guess we can not use the same matrix of contour point to get the area and de center of mass ... Or am I wrong ?
![2022-08-02 11_11_43-SMath Solver 1.0.8238 - [gpc3.sm_].png](/it-IT/files/Download/AzaWXh/2022-08-02-11_11_43-SMath-Solver-1.0.8238---[gpc3.sm_].png)
