Animate plots
Animate plots - Messaggi
#1 Pubblicato: 06/11/2019 06:41:56
hanskl
hanskl
7 apprezzamenti in 158 post.
Hi guys.
Seeing how fast I got great and helpful answers yesterday, I thought I might ask another rather silly question. I am trying to animate a plot, and I have never done it before.
I have made a simple sheet ploting V,M for a rectangular simply supported beam with uniformly distributed load. I have also plotted sigma and tau for the section, as well as Von Mises.
I have tried to make 3D plots to show how stresses evovle through the length of the beam, and to some extent it illustrates that.
I have also tried to animate a 2D plot, to work like a cross section that moves along the length of the beam, but I cannot figure out how to make it work.
Any ideas where it went wrong for me?
Also; is it possible to plot stresses along y-axis as opposed to x-axis?
Thanks again :d
spenninger bjelke.sm (30,46 KiB) scaricato 1237 volta(e).
#2 Pubblicato: 06/11/2019 11:11:51
Oh !!! too many questions in there.
Some typical animations:
0Anim Brownian.sm (9,94 KiB) scaricato 1173 volta(e).
0Anim Butterfly.sm (15,42 KiB) scaricato 1205 volta(e).
0Anim Analemma.sm (29,27 KiB) scaricato 1216 volta(e).
0Anim Brownian 3D [Ber7].sm (24,55 KiB) scaricato 973 volta(e).
0Anim CONVOLUTION.sm (27,89 KiB) scaricato 1152 volta(e).
0Anim Cheval.sm (21,64 KiB) scaricato 1190 volta(e).
0Anim Lorenz Attractor.sm (6,08 KiB) scaricato 1265 volta(e).
0Anim Ellipse.sm (13,85 KiB) scaricato 1194 volta(e).
0Anim Lorenz Attractor Norm2r.sm (10,48 KiB) scaricato 1225 volta(e).
0Anim Gozilla.sm (11,57 KiB) scaricato 1184 volta(e).
0Anim Model [Lissajous, Brownian, Butterfly].sm (39,48 KiB) scaricato 1028 volta(e).
0Anim Trifolium [Windmill Ber7].sm (25,85 KiB) scaricato 1035 volta(e).
0Anim Trifolium [Windmill].sm (17,34 KiB) scaricato 986 volta(e).
#3 Pubblicato: 06/11/2019 12:31:32
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
Check out this thread
https://en.smath.com/forum/yaf_postst1068_Beam-calculation.aspx
#4 Pubblicato: 06/11/2019 12:51:59
1. Yes as discrete format ... augment(y,x) in reverse order.
2. surface 3D does not save settings. Plot f,g,j
not you had plot f(x,y) ...
3. can't doctor the last plot ... proved otherwise.
spenninger bjelke _1.sm (55,57 KiB) scaricato 1209 volta(e).
#5 Pubblicato: 06/11/2019 17:45:06
hanskl
hanskl
Wowzers!
#6 Pubblicato: 06/11/2019 17:47:42
hanskl
hanskl
Thanks Jean!
I will try to plot about y-axis with the augment function.
Surface 3D not saving settings explains a lot! I think I tried to save those settings at least 10 times before giving up.
I will try to understand how plot animations work, and come back with a animated plot of my stresses..
Best regards,
Hans Kristian.
#7 Pubblicato: 06/11/2019 18:58:23
hanskl
hanskl
Well, I got the animations to work. I guess the mistake was to try to animate on a variable named 't'.
With a bit more tinkering I should be able to plot my stresses about y-y axis as well.
Best regards,
Hans Kristian
spenninger bjelke.sm (32,03 KiB) scaricato 1259 volta(e).
#8 Pubblicato: 06/11/2019 21:25:26
I saved it under your name [Project Hans].
Always credit what's not personal.
#9 Pubblicato: 07/11/2019 00:31:04
... that one is for training your Olympic Monkey !
First: show him the Smath video ... enjoy.
0Anim Fourier MonkeyBranching.sm (14,48 KiB) scaricato 1239 volta(e).
#10 Pubblicato: 07/11/2019 06:06:33
hanskl
hanskl
I find it somewhat funny my simple stress visualization sheet was something you deemed worthy of saving on your harddrive.
Thanks,
Hans Kristian
#11 Pubblicato: 07/11/2019 18:07:53
It carries units so nicely, not usual vs so many projects
that fail [Units don't match].
The attach breakfast with chicken rather than eggs.
At least, my small laptop does not smoke.
Pattern Julia Set [PUBLISH].sm (25,09 KiB) scaricato 998 volta(e).
#12 Pubblicato: 08/11/2019 07:08:47
hanskl
hanskl
Thank you!
Mine actually managed this sheet in 1.2 minutes.. :d
#13 Pubblicato: 08/11/2019 13:31:53
Fridel Selitsky
Fridel Selitsky
Another variation of Jean animation
0Anim Fourier MonkeyBranching 1.sm (18,08 KiB) scaricato 1218 volta(e).
#14 Pubblicato: 08/11/2019 14:58:53
Gruppo: Super Administrator
0.8 min using latest 7251:
Significant (20x) performance improvement for 3 years.
#15 Pubblicato: 08/11/2019 21:42:22
Impressive improvement ... MCD 11 XP Pro [4 sec]
Thanks Andrey ... Jean
