Animate plots
Animate plots - Сообщения
#1 Опубликовано: 06.11.2019 06:41:56
hanskl
hanskl
7 сообщений из 158 понравились пользователям.
Hi guys.
Seeing how fast I got great and helpful answers yesterday, I thought I might ask another rather silly question. I am trying to animate a plot, and I have never done it before.
I have made a simple sheet ploting V,M for a rectangular simply supported beam with uniformly distributed load. I have also plotted sigma and tau for the section, as well as Von Mises.
I have tried to make 3D plots to show how stresses evovle through the length of the beam, and to some extent it illustrates that.
I have also tried to animate a 2D plot, to work like a cross section that moves along the length of the beam, but I cannot figure out how to make it work.
Any ideas where it went wrong for me?
Also; is it possible to plot stresses along y-axis as opposed to x-axis?
Thanks again :d
spenninger bjelke.sm (30,46 КиБ) скачан 1232 раз(а).
#2 Опубликовано: 06.11.2019 11:11:51
Oh !!! too many questions in there.
Some typical animations:
0Anim Brownian.sm (9,94 КиБ) скачан 1168 раз(а).
0Anim Butterfly.sm (15,42 КиБ) скачан 1201 раз(а).
0Anim Analemma.sm (29,27 КиБ) скачан 1211 раз(а).
0Anim Brownian 3D [Ber7].sm (24,55 КиБ) скачан 968 раз(а).
0Anim CONVOLUTION.sm (27,89 КиБ) скачан 1149 раз(а).
0Anim Cheval.sm (21,64 КиБ) скачан 1186 раз(а).
0Anim Lorenz Attractor.sm (6,08 КиБ) скачан 1261 раз(а).
0Anim Ellipse.sm (13,85 КиБ) скачан 1189 раз(а).
0Anim Lorenz Attractor Norm2r.sm (10,48 КиБ) скачан 1222 раз(а).
0Anim Gozilla.sm (11,57 КиБ) скачан 1181 раз(а).
0Anim Model [Lissajous, Brownian, Butterfly].sm (39,48 КиБ) скачан 1023 раз(а).
0Anim Trifolium [Windmill Ber7].sm (25,85 КиБ) скачан 1030 раз(а).
0Anim Trifolium [Windmill].sm (17,34 КиБ) скачан 981 раз(а).
#3 Опубликовано: 06.11.2019 12:31:32
Fridel Selitsky
Fridel Selitsky
Check out this thread
https://en.smath.com/forum/yaf_postst1068_Beam-calculation.aspx
#4 Опубликовано: 06.11.2019 12:51:59
1. Yes as discrete format ... augment(y,x) in reverse order.
2. surface 3D does not save settings. Plot f,g,j
not you had plot f(x,y) ...
3. can't doctor the last plot ... proved otherwise.
spenninger bjelke _1.sm (55,57 КиБ) скачан 1206 раз(а).
#5 Опубликовано: 06.11.2019 17:45:06
hanskl
hanskl
Wowzers!
#6 Опубликовано: 06.11.2019 17:47:42
hanskl
hanskl
Thanks Jean!
I will try to plot about y-axis with the augment function.
Surface 3D not saving settings explains a lot! I think I tried to save those settings at least 10 times before giving up.
I will try to understand how plot animations work, and come back with a animated plot of my stresses..
Best regards,
Hans Kristian.
#7 Опубликовано: 06.11.2019 18:58:23
hanskl
hanskl
Well, I got the animations to work. I guess the mistake was to try to animate on a variable named 't'.
With a bit more tinkering I should be able to plot my stresses about y-y axis as well.
Best regards,
Hans Kristian
spenninger bjelke.sm (32,03 КиБ) скачан 1251 раз(а).
#8 Опубликовано: 06.11.2019 21:25:26
I saved it under your name [Project Hans].
Always credit what's not personal.
#9 Опубликовано: 07.11.2019 00:31:04
... that one is for training your Olympic Monkey !
First: show him the Smath video ... enjoy.
0Anim Fourier MonkeyBranching.sm (14,48 КиБ) скачан 1235 раз(а).
#10 Опубликовано: 07.11.2019 06:06:33
hanskl
hanskl
I find it somewhat funny my simple stress visualization sheet was something you deemed worthy of saving on your harddrive.
Thanks,
Hans Kristian
#11 Опубликовано: 07.11.2019 18:07:53
It carries units so nicely, not usual vs so many projects
that fail [Units don't match].
The attach breakfast with chicken rather than eggs.
At least, my small laptop does not smoke.
Pattern Julia Set [PUBLISH].sm (25,09 КиБ) скачан 994 раз(а).
#12 Опубликовано: 08.11.2019 07:08:47
hanskl
hanskl
Thank you!
Mine actually managed this sheet in 1.2 minutes.. :d
#13 Опубликовано: 08.11.2019 13:31:53
Fridel Selitsky
Fridel Selitsky
Another variation of Jean animation
0Anim Fourier MonkeyBranching 1.sm (18,08 КиБ) скачан 1214 раз(а).
#14 Опубликовано: 08.11.2019 14:58:53
Группа: Super Administrator
0.8 min using latest 7251:
Significant (20x) performance improvement for 3 years.
#15 Опубликовано: 08.11.2019 21:42:22
Impressive improvement ... MCD 11 XP Pro [4 sec]
Thanks Andrey ... Jean
