1 pagine (8 elementi)
Nightly build: SMath Studio 0.96.4884 (16 May 2013) - Messaggi
Nightly build: SMath Studio 0.96.4884 available
Important notes
- This build created to fix critical errors introduced in SMath Studio 0.96.4884.
Latest changes (against SMath Studio 0.96.4875)
- Go to definition Context menu item implemented;
- Added ability to change language translation for SMath Viewer;
- Multiplication improved for symbolic library;
- Support for backgrounds images improved;
- Fixed issue appears if plug-in extends Region's context menu with item(s) contains hotkey binding;
- Loading of sm-files information for snippets or examples doesn't raise dependencies check anymore;
- Worksheet drawing performance improved;
- Executable files size reduced;
- Language files updated;
- Refactoring.
Download
SMathStudioDesktop.0_96_4884.Setup.msi (Date: 16.05.2013. File size: 1.67MB)
SMathStudioDesktop.0_96_4884.Portable.exe (Date: 16.05.2013. File size: 18.17MB) - .Net Framework 2.0 doesn't required - Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_96_4884.Mono.tar.gz (Date: 16.05.2013. File size: 883.22KB) - last version of Mono distributive required!
SMath crashes, when you try to access the context menu of the region if showInputData = "False".
WroteSMath crashes, when you try to access the context menu of the region if showInputData = "False".
Will check it. Thanks!
Here are the Details - we still can to "Continue"
System.NullReferenceException: Object reference not set to an instance of an object.
at SMath.Control.Worksheet.GetStaticContextMenuItems(RegionBase[] regions)
at ..(List`1 )
at ..(Object , EventArgs )
at System.Windows.Forms.ContextMenu.OnPopup(EventArgs e)
at System.Windows.Forms.ContextMenu.Show(Control control, Point pos, Int32 flags)
at System.Windows.Forms.ContextMenu.Show(Control control, Point pos)
at System.Windows.Forms.Control.WmContextMenu(Message& m, Control sourceControl)
at System.Windows.Forms.Control.WmContextMenu(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SMathStudio_Desktop
Assembly Version: 0.96.4884.25061
Win32 Version: 1.1.26.0
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/SMathStudio_Desktop.exe
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ioman
Assembly Version: 0.96.4884.25057
Win32 Version: 0.96.4884.25057
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/ioman.DLL
canvas
Assembly Version: 0.96.4884.25059
Win32 Version: 0.96.4884.25059
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/canvas.DLL
rview
Assembly Version: 0.96.4884.25060
Win32 Version: 0.96.4884.25060
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/rview.DLL
System.Xml
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
AlgLib
Assembly Version: 1.0.4876.41065
Win32 Version: 1.0.4876.41065
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/AlgLib.dll
NuLib
Assembly Version: 1.63.4884.25058
Win32 Version: 1.63.4884.25058
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/NuLib.DLL
customFunctions
Assembly Version: 1.0.4861.16984
Win32 Version: 1.0.4861.16984
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/customFunctions.dll
HTMLFileType
Assembly Version: 1.12.4884.25006
Win32 Version: 1.12.4884.25006
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/HTMLFileType.dll
ImageFileType
Assembly Version: 1.8.4884.25012
Win32 Version: 1.8.4884.25012
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/ImageFileType.dll
MapleWrapper
Assembly Version: 1.0.4662.20619
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/MapleWrapper.dll
NonLinearSolvers
Assembly Version: 1.0.4669.26927
Win32 Version: 1.0.4669.26927
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/NonLinearSolvers.dll
ODESolvers
Assembly Version: 1.0.4653.40991
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/ODESolvers.dll
PictureRegion
Assembly Version: 1.9.4884.25017
Win32 Version: 1.9.4884.25017
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/PictureRegion.dll
PlotRegion
Assembly Version: 1.8.4884.25023
Win32 Version: 1.8.4884.25023
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/PlotRegion.dll
SMathFileType
Assembly Version: 1.8.4884.25029
Win32 Version: 1.8.4884.25029
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/SMathFileType.dll
SpecialFunctions
Assembly Version: 1.10.4884.25035
Win32 Version: 1.10.4884.25035
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/SpecialFunctions.dll
TextRegion
Assembly Version: 1.9.4884.25041
Win32 Version: 1.9.4884.25041
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/TextRegion.dll
ViewerFileType
Assembly Version: 1.0.4884.25046
Win32 Version: 1.0.4884.25046
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/ViewerFileType.dll
XMCDFileType
Assembly Version: 1.11.4884.25052
Win32 Version: 1.11.4884.25052
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/XMCDFileType.dll
XYPlotRegion
Assembly Version: 0.1.4884.13578
Win32 Version: 0.1.4884.13578
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/XYPlotRegion.dll
System.Design
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
SyLib
Assembly Version: 1.30.4884.25058
Win32 Version: 1.30.4884.25058
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/SyLib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
at ..(List`1 )
mscorlib
SMathStudio_Desktop
System
System.Drawing
ioman
canvas
rview
System.Xml
AlgLib
NuLib
customFunctions
HTMLFileType
ImageFileType
MapleWrapper
NonLinearSolvers
ODESolvers
PictureRegion
PlotRegion
SMathFileType
SpecialFunctions
TextRegion
ViewerFileType
XMCDFileType
XYPlotRegion
System.Design
SyLib
enabled.
For example:
Davide Carpi 27/05/2013 04:20:00
Вячеслав, Radovan, спасибо!
Issue related to context menu fixed.
Вячеслав Мезенцев 16/05/2013 18:29:00, Radovan Omorjan 17/05/2013 00:59:00, Davide Carpi 27/05/2013 04:20:00
Try MapleWrapper. Doesn't work saving regions. No assembly for MaplePlot and Maple.
Result for Maple Plot (RegionHolder):
f4417ad2-3313-4b10-bcaf-96ac84d9c57d
2
4
5
decimal
&[DATE] &[TIME] - &[FILENAME]
Result for Maple (RegionEvaluable):
3
4
5
decimal
It doesn't have a placeholder but the tag is present.
Fixed. uni, please contact me via Skype.
When I try to insert the unit ( ° ) the Greek letter is removed.
[MATH]sin(θ)[/MATH]
Time() function works without an argument:
[MATH]time(#)[/MATH]
[MATH]sin(θ)[/MATH]
