Plot does not plot waveform
Plot does not plot waveform - Waveform does not always plot - suspect units - Messaggi
#1 Pubblicato: 03/07/2013 08:10:33
Rob
Rob
0 apprezzamenti in 8 post.
Hi Smath Team,
Great tool!
Sometimes a plot does not generate a waveform. I suspect it has something to do with units. Sometime when I start over, or change the order it works, but cannot figure it out. I have attached an recent example. Using 0.96 (build 4909).
Rob
SimpleRC.sm (5,72 KiB) scaricato 1374 volta(e).
#2 Pubblicato: 03/07/2013 08:33:59
127 apprezzamenti in 342 post.
You just zoom on the chart that it concerns
Scale: if you roll your mouse wheel it zooms both axes together. If you hold 'control' keyboard key (CTRL) at the same time it just zooms the vertical axis;if you use the mouse wheel holding the 'shift' keyboard key (↑) it zooms the horizontal axis.
You can know more at this link
https://smath.com/wiki/Graphs.ashx
#3 Pubblicato: 03/07/2013 15:52:02
Gruppo: Moderator
Scaling your plot by orders of magnitude with the mousewheel won't probably be fun. Better use appropriate scaling factors (units in your case)
#4 Pubblicato: 04/07/2013 08:10:54
Rob
Rob
Thank you both for your replies. Both methods worked (obviously now) - I will pay more attention to scaling from now on.
Rob
