include
include - include() function allow you to include simple definitions from other documents. - Messaggi
#101 Pubblicato: 15/04/2016 17:58:09
Ruben Sidranski
Ruben Sidranski
17 apprezzamenti in 465 post.
Using Jean's files in the same directory, I updated to Mike's sheet and compared it to UNI's pdf ... I still have an error in the re-definition of BETA. Using latest SMath and plugins.
This is on my work computer ... not the one at home.
BTW, I tried with both files on my desktop and in the "C" drive.
#102 Pubblicato: 15/04/2016 19:43:19
... just like this
#103 Pubblicato: 15/04/2016 23:43:26
Ruben Sidranski
Ruben Sidranski
Not that BETA ... the one to the right of "FIT" per my screenshot. Everything up to that point matches UNI's PDF. I've tried moving the "BETA" down. I think that is why I have red boxes below.
#104 Pubblicato: 16/04/2016 00:10:09
уни
уни
156 apprezzamenti in 355 post.
βNlin() redefined (βNlin() := include() = 4).
#105 Pubblicato: 25/07/2017 10:59:19
Bence
Bence
0 apprezzamenti in 8 post.
Hi!
Access to Windows Enviroment Variables would be really nice:
include("%SM_INCLUDE%\fn.sm"=10
Do you think it's possible?
Thank you
#106 Pubblicato: 26/07/2017 02:31:54
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Yes, it is possible. Will be in new release.
Davide Carpi 26/07/2017 06:49:00, Bence 26/07/2017 07:19:00
#107 Pubblicato: 26/07/2017 07:19:07
Bence
Bence
Awsome! Thank you!
#108 Pubblicato: 05/09/2017 04:52:41
Gruppo: Moderator
Updated (for SMath Studio 0.98.6437).
sergio 05/09/2017 12:13:00, frapuano 06/09/2017 09:09:00
#109 Pubblicato: 11/11/2018 06:06:36
Martin_B
Martin_B
22 apprezzamenti in 84 post.
Hi!
I updated to SMath Version 0.99.6884.
Include() cannot read Sheets saved with this SMath Version. The result looks like include(...)=0.
By examining the files I found the new worksheet tag. And the regions tag moved downwards.
after saving with 0.99.6884:
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<?application progid="SMath Studio Desktop" version="0.99.6884.37264"?>
<worksheet xmlns="http://smath.info/schemas/worksheet/1.0">
  <settings dpi="96">
    <shortcut>Formelsammlung</shortcut>
    <identity>
      <id>5f168c43-3307-422f-ab94-2a3c16977117</id>
      <revision>775</revision>
    </dependencies>
  </settings>
  <regions type="content">
    <region id="0" left="567" top="0" width="104" height="215" color="#000000" bgColor="#ffffff" fontSize="10">
      <math>
Maybe that's the reason?
#110 Pubblicato: 11/11/2018 11:43:47
Ryan Freund
Ryan Freund
20 apprezzamenti in 339 post.
I'm having the same issues.
#111 Pubblicato: 13/11/2018 07:41:52
Gruppo: Moderator
Updated (plugin version changed to 0.2.x.x). Try now.
Old worksheets must be saved in the new format.
#112 Pubblicato: 22/02/2019 07:44:06
Martin_B
Martin_B
found a little bug in include():
Strings containing only one space " " are imported as an empty string.
#113 Pubblicato: 22/02/2019 08:40:39
Gruppo: Moderator
Updated. Try now.
Martin_B 22/02/2019 09:02:00
#114 Pubblicato: 22/02/2019 09:00:54
Martin_B
Martin_B
What a quick answer!
I forgot to mention, that I use the latest stable 0.99.6884.
As the plugin is not offered through the plugins dialog, I downloaded the latest file directly and replaced the current one.
But that doesn't work:
#115 Pubblicato: 22/02/2019 10:20:27
Gruppo: Moderator
The plugin was compiled for a more recent SMath Studio, that's why you can't get it through the extensions manager and why you get the error message (in short the library rely on a different interface than the one available in your version, they can't talk each other)
#116 Pubblicato: 22/02/2019 13:21:17
Martin_B
Martin_B
Updated. Try now.
Is working, with 0.99.6988
Thanks a lot.
Could you update the plugin for the latest stable, please?
Edit:
I have a more comprehensive sheet, which I include:
now (0.99.6988 with updated include extension) the result of include is shown as usual (98 elements), but they are not accessible:
At first start a few equations were present, but finally I can't get it to work.
I can't even say, if the beta Smath app or if the extension is making troubles.
The old extension 0.2.6982.28030 works correctly, apart from " ".
#117 Pubblicato: 22/02/2019 22:14:45
Gruppo: Moderator
Updated. Added support for 0.99.6884.
Show me .log file from the plugin directory.
#118 Pubblicato: 23/02/2019 10:56:29
Martin_B
Martin_B
Here you are:
23.02.2019 14:51:58 [ERROR] Das Objekt des Typs "System.Xml.XmlWhitespace" kann nicht in Typ "System.Xml.XmlElement" umgewandelt werden.
>The object of type ... cannot be converted to ...<
#119 Pubblicato: 23/02/2019 13:10:39
Hi. Related, but in SMath:
#120 Pubblicato: 23/02/2019 21:24:05
Gruppo: Moderator
Updated. Try now.
Martin_B 24/02/2019 05:20:00
