include
include - include() function allow you to include simple definitions from other documents. - Messaggi
#141 Pubblicato: 04/01/2022 23:12:37
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
SMath Studio compatibility
Plugin updated ( ).
Changes:
- restored the possibility of nested call of the include() function;
- added support for list of files.
It is now possible to implement the Reference component.
4 utenti hanno apprezzato questo post
Davide Carpi 05/01/2022 11:09:00, sergio 05/01/2022 06:12:00, Ryan Freund 05/01/2022 15:23:00, João Felipe Seráfico Melo 05/01/2022 08:03:00
#142 Pubblicato: 07/01/2022 18:15:06
Gruppo: Moderator
Plugin updated.
Changes:
- added support for: numericupdown, pathpicker, mathcad block, script;
- lastError shows missing plugins for the last included file (function compares the dependencies of the include file with the current set of enabled plugins).
sergio 07/01/2022 18:45:00, Ryan Freund 07/01/2022 22:48:00
#143 Pubblicato: 18/02/2022 06:31:25
Chito
Chito
1 apprezzamenti in 6 post.
Hi uni,
Thanks for the new updates. I found a bug. If I have a text region that has a formula, formulas after it will not be included.
test_sheet.sm (4,39 KiB) scaricato 1644 volta(e).
test_include.sm (6,79 KiB) scaricato 1695 volta(e).
This was the last version where I knew that it worked:
Plugin updated. Please try.
Changes:
- added encoding of special characters in the text.
#144 Pubblicato: 19/02/2022 15:02:12
Gruppo: Moderator
Plugin updated. For now I don't know how to parse math equations inside text region correctly.
Changes:
- text region partially supported.
Chito 19/02/2022 19:31:00
