UPDATED: SMath Studio 0.98.5905 (02 March 2016)
UPDATED: SMath Studio 0.98.5905 (02 March 2016) - Messaggi
#1 Pubblicato: 01/03/2016 19:07:51
Gruppo: Super Administrator
SMath Studio 0.98.5905 available
Latest changes (against SMath Studio 0.97.5890)
  • Calculation performance significantly improved (see timings in the following screenshots);
  • SS-2297: Numeric comparing of matrices with different dimensions fixed (issue happened when values in both matrices were the same but dimensions differ);
  • Keystroke fixed for adding Separator region;
  • Logic of handling plug-ins to evaluate expressions completely redesigned (it became much more efficient);
  • Critical issues fixed happens for some types of evaluation plug-ins;
  • Fixed issue appears when two or more plug-ins handles the same Term;
  • List of loaded plug-ins sorted alphabetically into Extensions Manager;
  • MSI installer became 20% lighter then for previous version;
  • Automatic release date setting on build implemented (no incorrect dates in About dialog anymore);
  • Refactoring.
Download
P.S.: Congratulations on coming of the springtime!
5 utenti hanno apprezzato questo post
Radovan Omorjan 02/03/2016 07:59:00, ioan92 02/03/2016 05:15:00, Davide Carpi 01/03/2016 20:10:00, IVR 02/03/2016 15:16:00, Mike Kaganski 02/03/2016 19:18:00
#2 Pubblicato: 01/03/2016 19:26:31
Hello all.
I'm very excited about this release as it is actually the most significant code change for past several years. I've started working on core redesigning (in order to improve performance) on summer 2015 and today results are published! I did my best to provide full back compatibility for plug-ins, but I expect couple of them might be failed to load. If so, please let me know, so I could fix it.
This SMath Studio build passed all internal tests and I believe it is stable enough to start using it today, but just because of too many changes done it will be more safe to check all possible behaviors together before finally releasing it as Stable officially.
Best regards and happy playing with SMath Studio 0.98!
IVR 02/03/2016 15:17:00, Davide Carpi 01/03/2016 20:10:00, ioan92 02/03/2016 05:18:00, Alexander O. Melnik 01/03/2016 20:02:00, frapuano 02/03/2016 15:50:00
#3 Pubblicato: 01/03/2016 19:57:54
Alexander O. Melnik
Alexander O. Melnik
127 apprezzamenti in 498 post.
Gruppo: Moderator
Hello all.
Thank you Andrey, this update is most welcome!
To start off the bug hunt - something does not seem to work for summation:
... And for one reason or another a "attach file" icon is not visible in the forum post menu...
Here is the SMath expression code that does not work:
line 1 :
y':transpose(mat(-3*'m,3*'m,3*'m,-3*'m,1,4))
line 2 :
I.x:sum(((el(y',i))^2),i,1,N)
In the cloud: http://smath.info/cloud/sheet/MZvkmGNbq6
Error in the cloud version of SMath is different from the error in the local version
Davide Carpi 01/03/2016 20:11:00
#4 Pubblicato: 02/03/2016 00:23:13
NDTM Amarasekera
NDTM Amarasekera
130 apprezzamenti in 352 post.
Hi Andrey!
Thanks very much for the new version.
I observe the following.
1. FindRoot function does not work.
2. Definite integral does not work.
Davide Carpi 02/03/2016 04:41:00
#5 Pubblicato: 02/03/2016 03:14:33
Thank you all! Current nightly build is canceled and will not come as an update anymore. Will do release later this week after all issues is fixed.
For now I suggest you to uninstall 0.98 and install the latest available 0.97.
Sorry for inconvenience!
UPDATE: As we see issues is not actually related to SMath Studio itself, 0.98.5904 is now approved as a Beta again. It will be available via Extensions Manager if it is configured to display Beta-versions of files.
#6 Pubblicato: 02/03/2016 03:46:04
I do not see any errors. You need to specify N to calculate it (the same for last 0.97)
Davide Carpi 02/03/2016 05:40:00
#7 Pubblicato: 02/03/2016 03:47:40
Today ther is no file attachment in the post reply.
Attachment fixed for Nightly Build forum (feature was just disabled for this forum).
#8 Pubblicato: 02/03/2016 03:53:06
Everything works as expected for me:
Please help to reproduce.
#9 Pubblicato: 02/03/2016 03:57:09
Hello, Ioan.
Never mind on the unavoidable problems linked to the progress.
Thank you! Yes, together we are able to handle all possible complexities!
Davide Carpi 02/03/2016 12:22:00, ioan92 02/03/2016 05:28:00
#10 Pubblicato: 02/03/2016 05:48:07
Gruppo: Moderator
Not yet experienced problems, and indeed is faster than the 0.97, thank you very much
except some functions as Min and Max, belonging to a Davide's plugin.
Can you share an example, seems to me that they works
#11 Pubblicato: 02/03/2016 08:05:51
NDTM Amarasekera
NDTM Amarasekera
The following file worked well in Smath 97.5890 up to yesterday.
But under the latest version, the calculation for definite integral gives an error.
Can somebody help me in this regard please?
Reservoir Flood Capacity Estimation-R1.sm (190,72 KiB) scaricato 1586 volta(e).
#12 Pubblicato: 02/03/2016 09:11:41
Gruppo: Moderator
Hi Andrey!
It will not work for me as well, although I have to admit that I installed bunch of plugins.
However, fresh install with only Davide's Nonlinear Solvers (FindRoot() function is from there) and Martin's Smath Handbook will give this
1. FindRoot() will give the same error as on the picture
2. Definite integral works
Davide Carpi 02/03/2016 09:39:00
#13 Pubblicato: 02/03/2016 09:35:30
Gruppo: Moderator
NonlinearSolvers updated, try now
I have no problems with integrals, no exceptions in the files above (Reservoir Flood Capacity Estimation-R1 / TestSum).
Andrey Ivashov 02/03/2016 10:29:00
#14 Pubblicato: 02/03/2016 09:53:58
Gruppo: Moderator
Cannot reproduce
ioan92 02/03/2016 10:35:00
#15 Pubblicato: 02/03/2016 10:14:13
Ruben Sidranski
Ruben Sidranski
17 apprezzamenti in 465 post.
Thank you Andrey and to all the developers!
Still hoping for an official portable version ...
Any information on the symbolics? I am trying to recreate a "proof" from a Mathcad file and I'm missing some features (or cannot find). Are we allowed to post Mathcad files on this forum? If so, I will post all of the relevant files.
#16 Pubblicato: 02/03/2016 10:59:16
Gruppo: Moderator
@Radovan,
@Davide,
Please, can you reproduce the error with the file in post #18?
Small delta region can be desabled.
Best Regards,
Ioan
I can reproduce this on the machine with many plugins, but on the machine with almost no additional plugins it was correct.
Therefore, chasing for the problematic plugin should be performed regarding these problems (integration, summation etc).
@Davide
Did you update the Numerical Solvers? I did not find any difference yet regarding FindRoot() problem
#17 Pubblicato: 02/03/2016 11:00:02
Alexander O. Melnik
Alexander O. Melnik
Gruppo: Moderator
Hi Andrey, apologize for confusion. I have a 30 page SMath file that does not run on 0.98; The error points down to the summation function - I will attempt to replicate it again and post the .sm file here
#18 Pubblicato: 02/03/2016 11:16:28
Gruppo: Moderator
Hi Andrey!
Try to install a fresh version without any not needed plugin for this file.
I suppose it might work, not sure.
#19 Pubblicato: 02/03/2016 11:29:36
NDTM Amarasekera
NDTM Amarasekera
Hi Radovan,
I had a bunch of so many plugins.
So, uninstalled, including all plugins in %APPDATA%/Smath folder and did a clean install.
My problem was solved.
Thank you very much.
#20 Pubblicato: 02/03/2016 11:48:57
Ruben Sidranski
Ruben Sidranski
...Any information on the symbolics? I am trying to recreate a "proof" from a Mathcad file and I'm missing some features (or cannot find). Are we allowed to post Mathcad files on this forum? If so, I will post all of the relevant files.
Specifically, I thought that "symbolic solve of algebraic equations" was implemented in version .9X. Keywords in symbolics would be fantastic too!
From Mathcad
