min function not defined
min function not defined - min function not defined - Messaggi
#1 Pubblicato: 27/09/2024 03:40:02
nominal_diameter
nominal_diameter
0 apprezzamenti in 5 post.
I'm struggling with the 'min' function. Could someone please point out where I'm going wrong? Thank you.
#2 Pubblicato: 27/09/2024 13:36:11
Gruppo: Moderator
Hi [userlink]nominal_diameter[/userlink],
as stated in the function description, min() returns the minimum value of a vector (or matrix), in a single argument. Same goes for max().
#3 Pubblicato: 27/09/2024 14:03:38
ioan92
ioan92
181 apprezzamenti in 125 post.
Hi nominal_diameter,
Try this way:
#4 Pubblicato: 27/09/2024 20:43:15
nominal_diameter
nominal_diameter
Thank you both for the response.
ioan92, the software won't allow me to use semicolons instead of comas, nothing happens when I push the semicolon button. How do I insert the semicolon?
Besides the semicolons, is there any difference that I'm missing?
#5 Pubblicato: 27/09/2024 21:49:25
Gerry_Bush
Gerry_Bush
12 apprezzamenti in 14 post.
Hi nominal_diameter
It is the use of the Min function rather than the min function that is important in this case.
The semicolon or comma is just the default separator for the list of values, set in the Tools menu under Options.
ioan92 27/09/2024 22:48:00
#6 Pubblicato: 27/09/2024 23:01:19
nominal_diameter
nominal_diameter
I've tried using the Min function and still get the same result. I also tried entering a string of numbers to see if that would work, but no luck yet.
#7 Pubblicato: 27/09/2024 23:43:40
Gruppo: Moderator
What is the error message returned by the function?
(Hover the mouse over the region to display the popup baloon or use the lastError variabile to display as string on canvas)
#8 Pubblicato: 27/09/2024 23:54:13
nominal_diameter
nominal_diameter
Hi Davide,
On both Min and min, the baloon says function is not defined.
#9 Pubblicato: 28/09/2024 00:14:12
Gruppo: Moderator
It Is possible that you don't have the Custom functions plugin installed.
If that's the case, inside SMath Studio:
- go to Tools > Plugins...;
- switch Local storage into Online gallery;
- search the plugin in the list;
- download it.
Alternatively if you open a worksheet that contains a function from that plugin, the program will prompt a dialog to install it.
Once installed you should be able to use those functions, unless there is some bug 🐛, in that case we will investigate it further.
#10 Pubblicato: 28/09/2024 00:28:58
ioan92
ioan92
Please load the attached file from my message and tell us what happens.
nominal.sm (4,2 KiB) scaricato 1776 volta(e).
regards,
Ioan
#11 Pubblicato: 28/09/2024 02:42:39
nominal_diameter
nominal_diameter
I didn't have the custom functions installed! I'm relatively new to Smath, I just recently switched over from mathcad. Thank you all for the help!
