SMath crashes!
SMath crashes! - This is an old file of mine whic produces SMath to crash - Messaggi
#1 Pubblicato: 08/05/2013 03:35:40
Gruppo: Moderator
This is an old file of mine which crashes SMath in the recent version as well. The same file was already mentioned some time ago, but it seems it remained problematic (at least for me). Maybe Andrey forgot about it . Could someone else try to just open it please in order to confirm the crash.
Primer43w.sm (33,99 KiB) scaricato 1619 volta(e).
#2 Pubblicato: 08/05/2013 04:02:33
Gruppo: Moderator
I can confirm the crash. If you disable automatic calculation in the settings, then you can load the file. Seems that the first call to roots() generates the problem.
Radovan Omorjan 08/05/2013 04:18:00
#3 Pubblicato: 08/05/2013 04:03:26
127 apprezzamenti in 342 post.
I confirm, it also crashes for me
Win64
#4 Pubblicato: 08/05/2013 04:24:11
Gruppo: Moderator
I nagged many times about roots(), and I hope that only roots() is the source of the problem. Anyway, this cause of crash should be removed, if possible. Fortunately, there is Davide Carpi (w3b5urf3r_reloaded) and his NonlinearSolvers plugin
#5 Pubblicato: 08/05/2013 05:32:06
kilele
kilele
134 apprezzamenti in 397 post.
No crashes for me in smath-mono.
Vista home basic 32-bit sp2
#6 Pubblicato: 08/05/2013 06:05:35
Gruppo: Moderator
Yes, I experienced the same thing before. Will test it again when I get to my Linux distro.
#7 Pubblicato: 09/05/2013 06:29:56
Gruppo: Super Administrator
Fixed.
Radovan Omorjan 09/05/2013 06:44:00, ioan92 09/05/2013 07:25:00, Davide Carpi 09/05/2013 08:49:00
