SMath crashes!
SMath crashes! - This is an old file of mine whic produces SMath to crash - Сообщения
#1 Опубликовано: 08.05.2013 03:35:40
This is an old file of mine which crashes SMath in the recent version as well. The same file was already mentioned some time ago, but it seems it remained problematic (at least for me). Maybe Andrey forgot about it . Could someone else try to just open it please in order to confirm the crash.
Primer43w.sm (33,99 КиБ) скачан 1628 раз(а).
#2 Опубликовано: 08.05.2013 04:02:33
I can confirm the crash. If you disable automatic calculation in the settings, then you can load the file. Seems that the first call to roots() generates the problem.
Radovan Omorjan 08.05.2013 04:18:00
#3 Опубликовано: 08.05.2013 04:03:26
I confirm, it also crashes for me
Win64
#4 Опубликовано: 08.05.2013 04:24:11
I nagged many times about roots(), and I hope that only roots() is the source of the problem. Anyway, this cause of crash should be removed, if possible. Fortunately, there is Davide Carpi (w3b5urf3r_reloaded) and his NonlinearSolvers plugin
#5 Опубликовано: 08.05.2013 05:32:06
kilele
kilele
No crashes for me in smath-mono.
Vista home basic 32-bit sp2
#6 Опубликовано: 08.05.2013 06:05:35
Yes, I experienced the same thing before. Will test it again when I get to my Linux distro.
#7 Опубликовано: 09.05.2013 06:29:56
Группа: Super Administrator
Fixed.
Radovan Omorjan 09.05.2013 06:44:00, ioan92 09.05.2013 07:25:00, Davide Carpi 09.05.2013 08:49:00
