Vector representation of Strings?
Vector representation of Strings? - Messaggi
#1 Pubblicato: 21/09/2025 19:21:48
Stuart Bruff Y
Stuart Bruff Y
0 apprezzamenti in 4 post.
Is there a method within SMath for converting between strings and vectors of Unicode Points (or ASCII codes)? That is, a means of accomplishing what Mathcad's str2vec and vec2str do?
#2 Pubblicato: 21/09/2025 21:15:09
Gruppo: Moderator
You can use Maxima.
string.sm (5,5 KiB) scaricato 1315 volta(e).
Modificato 21/09/2025 21:16:32
Stuart Bruff Y 23/09/2025 13:46:30
#3 Pubblicato: 22/09/2025 00:33:10
Hi Stuart. Nice to read you. You can use the functions in this post: https://smath.com/en-US/forum/topic/bppdgC/String-utilities, which, while not very efficient, at least get the job done.
#4 Pubblicato: 23/09/2025 13:50:55
Stuart Bruff Y
Stuart Bruff Y
You can use Maxima.
Thanks, Martin.
Stuart
