One more about lens
One more about lens - Messaggi
#1 Pubblicato: 01/12/2024 01:52:00
Valery Ochkov
Valery Ochkov
67 apprezzamenti in 713 post.
How can we use here a Mathcad-block?
Lens-Mathcad-Block.sm (43,8 KiB) scaricato 1845 volta(e).
See too
https://en.smath.com/forum/yaf_postst25212_Lens.aspx
#2 Pubblicato: 01/12/2024 18:08:12
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Here the function rkfixed() can't process the incoming expressions correctly. The block has nothing to do with it, it does not perform detailed analysis of expressions.
This is a bug in the function. The function has not been tested for this case. I can't see what's wrong here right now.
Valery Ochkov 02/12/2024 15:44:00
#3 Pubblicato: 01/12/2024 19:52:45
Gruppo: Moderator
This is not a solution of the rkfixed problem, just a little playing around with X-Y plot.
Here, an option of setting the aspect ratio of the axes to 1 would be good.
Valery Ochkov 02/12/2024 15:45:00, francesco rapuano 03/12/2024 04:21:00
#4 Pubblicato: 07/12/2024 13:02:58
Valery Ochkov
Valery Ochkov
Mathcad Prime
#5 Pubblicato: 08/12/2024 01:05:34
Cornel
Cornel
2 apprezzamenti in 78 post.
I am wondering if there is such a kind of Mathcad Prime odesolve for solving differential equations numerically also for SMath Studio somehow?
#6 Pubblicato: 08/12/2024 01:21:21
Valery Ochkov
Valery Ochkov
Not yet, but will be soon!
Question - why is the answer meters squared, and not just meters?
#7 Pubblicato: 08/12/2024 02:29:44
Gruppo: Moderator
What's wrong with the existing solvers?
#8 Pubblicato: 08/12/2024 03:54:39
Cornel
Cornel
Because odesolve in Mathcad Prime:
1. Do not require to rewrite the differential equation of a higher order into a system of first order odes
2. Determines whether a system is stiff or nonstiff and then is using accordingly the stiff numerical differential eq solver or nonstiff numerical differential eq solver
3. Can solve numerically a system of differential equations (whatever it's a system of first order differential eq or a system of higher order differential eq)
What are these existing numerical solvers of differential eq in SMath? What are the posibilities of SMath to solve numerically differential equations? Exist at least one solver that mimic the Mathcad Prime odesolve (i.e. the 3 points above menționed)?
#9 Pubblicato: 08/12/2024 05:04:39
Hi Cornel. For points 1 and 3, SMath can do what Mathcad can, and just a little more. Please, check the first post in this plugin. Can mathcad solve this odes?
RKA.sm (308,62 KiB) scaricato 2262 volta(e).
RKA.pdf (931,16 KiB) scaricato 1729 volta(e).
About point 2, one would have to review the documentation for the following plugins to see if they are capable, and to what extent, of doing what you are asking, and choose it for the solver in the SMath's solver block.
● [topic=17088]Intel ODE Solver Library[/topic]
● [topic=1918]DotNumerics[/topic]
● [topic=13809]SADEL[/topic]
● [topic=1970]Matlab C++ Math Library[/topic]
● [topic=17063]OSLO[/topic]
● [topic=17067]lsoda[/topic]
● [topic=1997]GNU Scientific Library (GSL)[/topic]
#10 Pubblicato: 08/12/2024 08:58:47
See too
Hi. dsol can solve it with this setup:
RKA-Lens.sm (179,91 KiB) scaricato 1816 volta(e).
I also use the Martin's setup for the plot.
#11 Pubblicato: 09/12/2024 10:44:48
Valery Ochkov
Valery Ochkov
How to create this picture
https://en.wikipedia.org/wiki/Spherical_aberration
#12 Pubblicato: 10/12/2024 04:11:05
Hi Valery. This is a way.
spherical aberration.sm (15,88 KiB) scaricato 1806 volta(e).
Oscar Campo 10/12/2024 09:43:00, Valery Ochkov 10/12/2024 12:26:00
#13 Pubblicato: 10/12/2024 12:38:25
Valery Ochkov
Valery Ochkov
Thanks!
The last step
#14 Pubblicato: 10/12/2024 21:21:41
Hi. The screen. I also simplify a little the calculations.
spherical aberration.sm (26,41 KiB) scaricato 1958 volta(e).
francesco rapuano 10/12/2024 23:05:00, NDTM Amarasekera 10/12/2024 23:16:00, Вячеслав Мезенцев 10/12/2024 23:19:00
#15 Pubblicato: 10/12/2024 21:35:39
Oscar Campo
Oscar Campo
135 apprezzamenti in 309 post.
Gruppo: Moderator
Very elegant solution
Alvaro 11/12/2024 06:18:00
#16 Pubblicato: 11/12/2024 03:06:13
Gruppo: Moderator
Root-free version of the spherical lens
spherical aberration_Kr.sm (12,37 KiB) scaricato 1741 volta(e).
#17 Pubblicato: 11/12/2024 06:22:06
Gracias Oscar! Pero espérate tantito nomás para que veas lo que puede hacer un doc alemán.
Thanks Oscar! But wait a little longer so you can see what a German doctor can do.
Oscar Campo 11/12/2024 12:09:00
#18 Pubblicato: 12/12/2024 04:49:07
Gruppo: Moderator
Oscar Campo 12/12/2024 18:29:00, Alvaro 13/12/2024 07:27:00
