1 pagine (9 elementi)
error: result is above max - Messaggi
hi,
I'm a beginner
I get an error in the calculation
error :
result is above max. Allowed positive number
How can I solve it?
impedance.sm (34,02 KiB) scaricato 1217 volta(e).
I'm a beginner
error :
How can I solve it?
Thank you
I understand the cause of the error
WroteThank you.
I was able to calculate the frequency characteristics
(PP2.sm)
But when I modify a circuit, I get an error even with eval.
(PPS.sm)
it's very difficult.
... sorry, can't help: this document opens freak SS 6179.
You seem to put too much that can't be debugged piece wise.
WroteThank you.
(PP2.sm)
(PPS.sm)
PPS.sm (176,46 KiB) scaricato 1221 volta(e).
PP2.sm (167,69 KiB) scaricato 1225 volta(e).
Hi Takez. Yes, it's very difficult recognize or even guess where the program needs some evals. Also, putting them everywhere make unreadable the procedures. In the case of your PPS.sm that's SMath stores into Z without eval
and this with it
So, for PPS.sm there is where you need to use eval, and seems that then all other calculations works.
