num2str problem with sum
num2str problem with sum - BTS issue SS-43 - Messaggi
#1 Pubblicato: 24/08/2013 01:42:23
Gruppo: Moderator
num2str() fails to convert a sum to a string. In the sum(1) example "syntax is incorrect", in the sum(4) example "n is not defined".
Edit: This is now BTS issue SS-43
#2 Pubblicato: 24/08/2013 03:48:22
127 apprezzamenti in 342 post.
I confirm and add some further example.
[albumimg]284[/albumimg]
[smath 0.96 (build 4884) W7 64bit]
#3 Pubblicato: 20/09/2013 12:26:06
Gruppo: Moderator
This is the current state. sum() now can produce symbolic results.
num2str() should provide a string corresponding to the unevaluated expression if it cannot be evaluated.
