Smath Solver
Smath Solver - Messaggi
#1 Pubblicato: 21/01/2022 06:45:25
Beyaz
Beyaz
0 apprezzamenti in 19 post.
Im trying convert this mathcad solver to smath but it doesnt work.
Radius_318a.sm (9,34 KiB) scaricato 1288 volta(e).
#2 Pubblicato: 21/01/2022 11:44:53
127 apprezzamenti in 342 post.
It is a non-linear system. With the internal "Roots" solver it is appropriate to use initial values ​​sufficiently close to the result.
You can use some of the smath plugins that are more robust. For example, with "Solve" of the "Maxima plugin you get the result.
Mostra spoiler
Radius_318a_ser.sm (337,14 KiB) scaricato 1363 volta(e).
#3 Pubblicato: 21/01/2022 17:30:18
Gruppo: Moderator
With an addition to sergio's solution;
You can use vectors while solving.
#4 Pubblicato: 21/01/2022 20:59:15
Gruppo: Moderator
Solution with another solver.
al_nleqsolve.sm (6,99 KiB) scaricato 1257 volta(e).
#5 Pubblicato: 26/01/2022 03:52:33
Beyaz
Beyaz
wow, thanks a lot guys.
//Edit: the thanks button is not working. I cant give you thanks
