Animation Compendium
Animation Compendium - Animation Compendium - Messaggi
#1 Pubblicato: 21/08/2016 21:05:22
Animation adds live to projects.
Enjoy your vist.
0Anim Brownian.sm (8,86 KiB) scaricato 1556 volta(e).
0Anim Analemma.sm (28,67 KiB) scaricato 1437 volta(e).
0Anim Ellipse.sm (13,42 KiB) scaricato 1478 volta(e).
0Anim Cheval.sm (21,13 KiB) scaricato 1511 volta(e).
0Anim Gozilla.sm (11,26 KiB) scaricato 1452 volta(e).
0Anim XFR.sm (11,65 KiB) scaricato 1492 volta(e).
Davide Carpi 22/08/2016 12:05:00
#2 Pubblicato: 21/08/2016 22:13:52
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
Hi Jean
The program will run faster if the code is a little change
0Anim XFR1.sm (13,23 KiB) scaricato 1446 volta(e).
Davide Carpi 22/08/2016 12:04:00
#3 Pubblicato: 22/08/2016 00:56:24
Thanks Ber7 for the code.
On that one "0Anim CONVOLUTION" ... can't accumulate the path ?
Cheers, Jean
0Anim CONVOLUTION.sm (18,42 KiB) scaricato 1477 volta(e).
#4 Pubblicato: 22/08/2016 03:57:54
Fridel Selitsky
Fridel Selitsky
Instead tmin = 0 substitute the tmin=1
0Anim XFR1.sm (13,23 KiB) scaricato 1490 volta(e).
#5 Pubblicato: 22/08/2016 08:52:26
0Anim CONVOLUTION .sm
has been doctored for the accumulated path.
Plots are difficult to size, work sheet is Autocal OFF
0Anim CONVOLUTION.sm (30,72 KiB) scaricato 1517 volta(e).
#6 Pubblicato: 22/08/2016 12:35:58
Gruppo: Super Administrator
Thank you for interesting examples!
I've checked your worksheets and see one place for simple optimization applicable for most of them.
Often you use procedures to draw static set of points for all frames of animation. Procedures (when line is used right after the definition operator) calculated on every call - SMath Studio do not precalculate their values.
So, you can speed up calculation simply by line like this:
This line asks the program to calculate procedure and store its values into the initial procedure variable. So, we have only one calculation of static shape for the whole animation!
I've corrected your examples according to the hint above and tested them in both versions: 0.97.5346 - the one you have used to create files and 0.98.6077 - the latest nightly build. Here are the results:
Final versions of the worksheets:
Fridel Selitsky 22/08/2016 12:43:00, frapuano 22/08/2016 15:11:00, Davide Carpi 23/08/2016 04:25:00
#7 Pubblicato: 22/08/2016 21:39:48
Thanks Andrey: I toke good note and adapted.
