1 pagine (8 elementi)
How to get explict parametric function - Messaggi
You can get discrete values and then interpolate them.
The Dadras Attractor.sm (15,16 KiB) scaricato 1219 volta(e).
Oscar Campo 19/07/2021 09:02:00
Thank you for the numerical solution.
How to get symbolic solution?
Not sure if chaos can be described symbolically.
Hi. For show the four plots at once.
DadrasAttractor.sm (46,22 KiB) scaricato 1234 volta(e).
Fridel Selitsky 27/07/2021 03:46:00
Thanks for the 3D image
WroteHow to get explict parametric function, like x=x(t), y=y(t), z=z(t) from above equations?
Now it is possible.
Dadras Attractor.sm (20,15 KiB) scaricato 1218 volta(e).
The Aizawa Attractor.sm (21,51 KiB) scaricato 1203 volta(e).
Links:
1. https://github.com/tmhglnd/strange-attractor-synth
2. https://www.deviantart.com/chaoticatmospheres/gallery/44050549/strange-attractors
3. The Aizawa Attractor (youtube)
4 utenti hanno apprezzato questo post
Alvaro 31/12/2021 10:14:00, NDTM Amarasekera 31/12/2021 06:05:00, Fridel Selitsky 31/12/2021 03:12:00, Andrey Ivashov 31/12/2021 07:05:00
The Aizawa Attractor animation
Calculation points are equidistant
Aizawa Attractor.sm (15,78 KiB) scaricato 1199 volta(e).
Вячеслав Мезенцев 01/01/2022 12:22:00
