Why I have errors?
Why I have errors? - See please the attached file - Messaggi
#1 Pubblicato: 14/10/2023 15:31:44
Valery Ochkov
Valery Ochkov
67 apprezzamenti in 713 post.
See please the end of the attached file.
6-1-Mister-Class.sm (33,29 KiB) scaricato 1282 volta(e).
#2 Pubblicato: 14/10/2023 21:38:32
Triplet roots ... FindRoot not doctored.
6-1-Mister-Class (1).sm (66,16 KiB) scaricato 1297 volta(e).
#3 Pubblicato: 14/10/2023 21:42:14
Gruppo: Moderator
The first error can be handled by wrapping the function in eval(). For the second one this does not help.
I take the opportunity to advertise the Maxima Fit() function.
It is explained in https://doi.org/10.25933/opus4-2949 chapter 6 (English) and in https://doi.org/10.25933/opus4-2948, chapter 9 (German).
6-1-Mister-Class Kr.sm (56,11 KiB) scaricato 1333 volta(e).
Valery Ochkov 14/10/2023 21:45:00
#4 Pubblicato: 14/10/2023 21:53:20
Valery Ochkov
Valery Ochkov
And the Lord God created the function eval and the lord said this is good!
And the Lord God created the Maxima and the lord said this is sehr kompliziert!
#5 Pubblicato: 14/10/2023 22:52:25
Gruppo: Moderator
Hm, where exactly do you see the most severe сложности in the use of the Maxima plugin? Perhaps everything that needs a handbook is too complicated nowadays
I really like the curve fitting interface with the Fit() function, which might even be comprehensible from the подсказка in the dynamic help.
#6 Pubblicato: 15/10/2023 00:19:13
Hi. Polynomial fitting, returning the same values that Excel returns. From this post.
fit_CKO.sm (51,22 KiB) scaricato 1390 volta(e).
#7 Pubblicato: 15/10/2023 14:35:01
Valery Ochkov
Valery Ochkov
Sorry!
But the question was Why not How
#8 Pubblicato: 15/10/2023 19:51:16
Sorry!
Hi Valery. Martin showed why. But for the quadratic case Máxima's Fit function does not return the same result as Excel, which could be said to have been taken as standard, since they are also the same as those usually obtained with the 'all powerful' (talking about of gods) a\b of Matlab. I made the post to show how those mythical values can also be obtained in SMath.
Because SMath' solver isn't very powerful you can get those same values with your method using another, like the following one
About the error vectorizing, you can see why taking a look of this
Valery Ochkov 15/10/2023 20:03:00
#9 Pubblicato: 15/10/2023 20:04:14
Valery Ochkov
Valery Ochkov
Sorry!
Send please sm-file!
#10 Pubblicato: 15/10/2023 20:48:34
6-1-Mister-Class with polyfit.sm (39,08 KiB) scaricato 1360 volta(e).
6-1-Mister-Class with polyfit.pdf (226,49 KiB) scaricato 795 volta(e).
Valery Ochkov 15/10/2023 21:20:00
#11 Pubblicato: 15/10/2023 23:25:44
Gruppo: Moderator
There is not much sense in fitting functions with many degrees of freedom to data containing not much information. Any function which goes through the centroid of the data points will come up with a similar MSE.
Is the second result really the best just because of it's lowest MSE?
#12 Pubblicato: 16/10/2023 00:33:28
Valery, as it looks all doctored.
Thanks Alvaro for the robust Broyden.
Curious, Solver 30405 Slope/Intercept back on foot.
6-1-Mister-Class (1).sm (65,74 KiB) scaricato 1289 volta(e).
#13 Pubblicato: 16/10/2023 01:06:59
Valery Ochkov
Valery Ochkov
And what about 3D fitting in SMath?
See please my old problem in Mathcad
http://twt.mpei.ac.ru/ochkov/car/c_e.html
Online calculation
http://twt.mpei.ac.ru/MCS/Worksheets/old-car.xmcd
#14 Pubblicato: 16/10/2023 05:57:28
Gruppo: Moderator
The second and third fit aren't really robust (quite some dependence on initial guesses)
Gebrauchtwagen.txt (729 B) scaricato 945 volta(e).
Gebrauchtwagen.sm (90,47 KiB) scaricato 1359 volta(e).
Valery Ochkov 16/10/2023 12:11:00
#15 Pubblicato: 16/10/2023 12:13:21
Valery Ochkov
Valery Ochkov
Wunderbar!
Send me please the M matrix as sm-file!
#16 Pubblicato: 16/10/2023 12:48:56
Online calculation
Another way, from the same previous post .
fit cars.sm (83,96 KiB) scaricato 1368 volta(e).
#17 Pubblicato: 16/10/2023 13:45:10
Valery Ochkov
Valery Ochkov
Thanks!
But the last plot must be so
#18 Pubblicato: 16/10/2023 15:32:33
Gruppo: Moderator
Wunderbar!
The data is from your website. I copy-pasted the table to a new text file and imported it. Just use the files provided in my post.
As to the last plot: I guess the mileage limits of the individual lines are taken from the minimum and maximum slope observed in the age-mileage plot (fig.2 in your reference)?
Do you see any particular problem or do you just want the work getting done?
#19 Pubblicato: 16/10/2023 18:38:46
Valery Ochkov
Valery Ochkov
Yes ;-)
#20 Pubblicato: 17/10/2023 00:58:58
Global fit Cholesky
Frequently, you can manage the Phi vector for a best regional fit.
Project fit cars Cholesky.sm (19,75 KiB) scaricato 1332 volta(e).
Valery Ochkov 17/10/2023 01:09:00
