1 pagine (14 elementi)
Unit Conversion - Change from International System Units to other derived units - Messaggi
Hello
Does anyone know how to change the following units in the matrix shown below?:
from "kg/s" to "t/hr",
from " kg/{'m*'s^2}" to meters Water Column ("mH2O"),
"{'kg*'m^2}/{'s^3}" to Watts.("W")
Colebrook_SI_CBG.sm (29,41 KiB) scaricato 1296 volta(e).
Carlos
Carlos
Hola Carlos. You can use matrix algebra in the unit placeholder. Here one solution.
Colebrook_SI_CBG.sm (24,74 KiB) scaricato 1328 volta(e).
WroteDoes anyone know how to change the following units in the matrix shown below?:
from " kg/{'m*'s^2}" to meters Water Column ("mH2O",
Hola, Carlos
Moody as stand alone.
WroteHola, Carlos
Relation with what Carlos asked?
None, as usual.
Hello
Many thanks to Overlord for his suggestions and solution.
Muchas Gracias tambien a Alvaro por su solucion.
I also thank Jean.
Carlos
I also thank Jean.
Carlos
WroteRelation with what Carlos asked?
None, as usual.
Project is Colebrook, of which the core algo is Moody.
Read Alvaro to learn more.
WroteRead Alvaro to learn more.
Reading you in mathcad forums is also instructive.
https://www.eng-tips.com/viewthread.cfm?qid=335795
WOW, I feel old. I didn't even remember I was on that forum/website. Thanks for the memory...
That moment you realize you didn't save a copy of the problem :/ just redid it and realized I have a lot to learn about this program
Thanks for the welcome
Coversion Problem.sm (26,14 KiB) scaricato 1307 volta(e).
WroteHow do I set my units so my answers are in the unit I want?
Your attached document is fine. Jean's computer is broken.
About your question, there is a placeholder within results.
It will appear when you select result. It appears as a black square.
You can change your desired result units by altering it.
Here is a demonstration how you can do that.
![2022-05-22 14_29_56-SMath Solver - [Practice Questions May 2022.sm_].png](/it-IT/files/Download/T65HNv/2022-05-22-14_29_56-SMath-Solver---[Practice-Questions-May-2022.sm_].png)
