Beta: SMath Studio 0.99.7792 (02 May 2021) - Messaggi
Offre numerose funzionalità di calcolo e un'interfaccia utente ricca, tradotta in circa 40 lingue diverse. L'applicazione include inoltre un prontuario matematico integrato.
L'applicazione può essere facilmente estesa in base alle proprie esigenze. Lo strumento integrato "Gestione estensioni" consente di accedere a centinaia di risorse, sia ufficiali che di terze parti, tra cui: esempi d'uso, plug-in, applicazioni basate su SMath Viewer, frammenti di codice, traduzioni dell'interfaccia, libri interattivi, manuali e tutorial.
Download
SMathStudioDesktop.0_99_7792.Mono.tar.gz (1,45 MiB) scaricato 2589 volta(e).
SMathStudioDesktop.0_99_7792.Setup.msi (2,33 MiB) scaricato 5496 volta(e).
I'm facing problems for selecting and moving objects with this update.
WroteHi, Andrey!
Me too, there is a performance drop with moving or scrolling regions.
WroteHi, Andrey!
How can I reproduce it?
WroteHi Andrey!
Problems with Formatted Label.
Apparently, it occurs when both text and background color is specified with "light ..." as shown.
To overcome this issue you need to remove spaces from color name (" "). I will fix this.
Thank you!
WroteWroteHi Andrey!
Thank you!
In the meantime I've added a workaround in the plugin.
WroteHow can I reproduce it?
Cleaning "~/.config/SMath" directory and reinstalling all plugins solved the performance issue.
Possibly would be resulted same with cleaning the "Roaming/SMath" directory under Windows.
WroteWroteWroteHi Andrey!
Thank you!
This workaround will not work.
You need to change line
SMath.Drawing.Graphics.GetColorByName(color.Replace(" ",""
SMath.Drawing.Graphics.GetColorByName(TermsConverter.DecodeText(color));
This is because variable color contains value from Term where text is always encoded. While GetColorByName does not except encoded values.
In case you want to see an example: I did the same correction in the Plot Region plug-in in my latest commit in main repo.
WroteOriginally Posted by: joaobr [url=/forum/yaf_postsm70583_Beta--SMath-Studio-0-99-7792--02-May-2021.aspx#post70583][/url]Hi, Andrey!
I too had this problem.
Even after a clean re-installation, the problem still exists.
WroteWroteOriginally Posted by: joaobr [url=/forum/yaf_postsm70583_Beta--SMath-Studio-0-99-7792--02-May-2021.aspx#post70583][/url]Hi, Andrey!
Please describe in details what are you experiencing.
When I open a selection box by holding the left click, it gets stucked, so I can't select objects and move them around.
I can select objects by clicking but can't drag them.
I'm testing right now and it happens only in worsheets created in previous versions.
Problem is as shown in post #13.
It occurs for files created in latest SS also.
Sorry for the delay.
WroteIt occurs for files created in latest SS also.
Did another clean-reinstallation.
Now the problem is solved only for new files saved in 99.7792.
But not for previous versions.
Thank you.
WroteDid another clean-reinstallation.
Do you mean for documents created in previous versions ?
As far back to previous versions ?
As well I noticed that last version affects "0.98.6179.21440"
Roots (range) options => Can't be set anymore ± 2.5
... Takes integers only or set it back to integer.
That happened from downloading some Forum latest version
even if denied updating like usual !
Take care ... Jean
WroteDo you mean for documents created in previous versions ?
Yes. The last one before 99.7792.
Previous versions also. Can't remember the version number but the dates are given below.
29/05/2014
19/05/2016
27/08/2016
21/06/2018
23/09/2.18
26/06/2019
23/01/2020
Thanks.
Take care.
Can't remember the version number ...
If you open the SMath file with a text editor, the second line shows the version:
e. g.
WroteIf you open the SMath file with a text editor, the second line shows the version:
e. g.
Thank you.
