Line intersections - An example of translation of a function from Matlab to Smath - Messaggi
Just an exercise on Smath to test functionalities and capabilities.
Try the attached file and play with it.
Thanks
Marco
InterX.sm (85,93 KiB) scaricato 1441 volta(e).
Thanks
Marco
Jean Giraud 18/02/2018 22:46:00
Thanks Marco, works fine 6179,
Great piece of work !
Hello ndtma,
L1 is defined just near tt. You may try to move the tt definition a bit below in the page, to be sure that L1 definition comes first.
Regarding indefinite running, please be advised that due to the more complicate example that comes below in the sheet, the full worksheet takes 6,5 minutes on a pretty good hardware. Other hardwares may require more time, that could seem an indefinite time...
Try deleting the more complicate example, leaving only the simple one.
It should run in less than 1 minute.
Thanks
Marco
Thanks
Marco
Ndtma,
maybe that's why:
Some plugins are required and in particular:
- Matlab C++ Math Library
Attention: to my knowledge,this plugin only works with 32 bit version of Smath.
I am using 0.98 build 6484 dated 02 Oct 2017.
maybe that's why:
Wrotethe full worksheet takes 6,5 minutes on a pretty good hardware
... ~ 21 min on my laptop [1.66 GHz]
Marco,
Just a detail: often we have to optimize project based on piecewise timing.
Smath accesses Microsoft internal timer, like this [attached].
Expect ~ 45 sec on your machine ... on mine => 1.6 min
Contour Butterfly.sm (14,26 KiB) scaricato 1277 volta(e).
Jean,
this is a fantastic feature I was not aware of!
I still have to look into the details but I think it is something like an animated GIF.
I'll go deeper in your worksheet later on to discover details.
Thanks for this hint!
Marco
Marco
Jean,
looking at your last post I have learnt a lot of things:
1) I didn't know that plots could be animated. This was a very nice example on this feature.
2) I didn't realize that placeholders can contain any kind of object. This means that definitions can be placed in a vector/matrix and treated as data. So instructions and data are on the same level (lisp docet!).
This opens the door to any kind of "black magic" like the simple example here attached.
3) Ahh..by the way I also understood about timing of code chunks...:d
For all the above... thx!
Marco
BlackMagic.sm (7,48 KiB) scaricato 1295 volta(e).
Marco
WroteJean,
Marco
Few more typical animations. The Grand Champion Animate is Collab BER7.
He takes my dead cat and up dancing, isn't nice !
You can pass to any Windows user and animation survives [a Windows feature].
0Anim Brownian.sm (9,94 KiB) scaricato 1271 volta(e).
0Anim Cheval.sm (21,64 KiB) scaricato 1288 volta(e).
0Anim Gozilla.sm (11,57 KiB) scaricato 1299 volta(e).
Rotate Eol.sm (28,47 KiB) scaricato 1247 volta(e).
Fridel Selitsky 07/12/2017 06:46:00
If we add the third coordinate to the worksheet of Jean, we get a 3d animation.
3d Anim Brownian.sm (17,35 KiB) scaricato 1233 volta(e).
frapuano 07/12/2017 14:58:00
Hello Marco,
On that one, for every calculated Ω, click on image, "Reset to original size"
Pattern Brownian Collect Image.sm (25,1 KiB) scaricato 1214 volta(e).
Still on line intersections.
Bug corrected: only lines with same number of points were accepted.
Now lines with different # of points will work.
Also some improvements in efficiency so that runtime is now
approx. -25%.
InterX.r1.sm (45,36 KiB) scaricato 1227 volta(e).
approx. -25%.
WroteStill on line intersections.
Some notes about "Vector partnership"
You mentioned Scilab [what a piece of software !!!], can't manage, removed from my box.
3D colors from whatever source is not available in Smath. Maxima as suggested by Martin,
complains ... useless. For your interest, Scilab should render the famous "Breather".
Attached as well.
Maths InterseX.r1.sm (65,4 KiB) scaricato 1267 volta(e).
Breather for UNI.sm (308,66 KiB) scaricato 1285 volta(e).
Rotate Breather [4 Orientations].sm (1000,85 KiB) scaricato 1082 volta(e).
WroteMaxima as suggested by Martin,
Did I miss the bug report?
![2017-12-08 22_51_18-SMath Studio - [Rotate1.sm].png](/it-IT/files/Download/RuwoN4/2017-12-08-22_51_18-SMath-Studio---[Rotate1.sm].png)
Rotate1.sm (296,76 KiB) scaricato 1277 volta(e).
frapuano 18/05/2020 14:27:00
WroteOn starting Smath session, some dependencies aren't accessed.
Starting Smath, always get that error message, close, up running fine.
As it looks, only the Maxima X_Y. 3D surface and those from menu work.
NONE of "draw 2D, 3D, implicit, explicit as you suggest ..." work.
Thanks Martin for being there in Smath Community.
Jean,
I tried to render the Breather in Scilab.
The code is as small as this:
and it runs as fast as this, considering that U and V are given with 100 points each:
and this is the result:
from this side seems ok, but moving it a little bit it appears like this:
I am not sure if this is the expected result, but however I spent only 15 min on it up to now.
I'll check better if I messed something.
Thanks
Marco
Thanks
Marco
Ok, using limits shown by Martin [(0, pi/2); (0, 2pi)]
I got something more similar to his result:
I'll work to see how to get the level curves.
Being Scilab an open source program, any chance that somebody could develop
a dedicated plugin?:d
Maybe this is more a subject for the "Feature Request" Forum...
Marco
Marco
WroteWroteOn starting Smath session, some dependencies aren't accessed.
Are you using the current stable or development version of SMath?
Older versions won't work with the current plugin, as there were significant changes in the API.
If you follow the link in my signature you find instructions how to install a portable distribution with Maxima. The benefit of having a portable installation is that it won't interfere with an installed version of SMath and can be tested separately. So you don't need to spoil your familiar working environment.
If maxima still won't work, then please report the system information as obtained with Insert> Development tools> System Information.
Thanks for your help.
