Conditionally Formatted Labels
Conditionally Formatted Labels - Add Conditionally Formatted Labels in SMath Studio worksheets - Messaggi
#81 Pubblicato: 17/01/2023 09:19:38
German
German
0 apprezzamenti in 8 post.
Here it is.
losa-forum.sm (862,11 KiB) scaricato 1920 volta(e).
Sorry Jean but i don't understand what i'm supposed to see. I also get "data - not defined".
#82 Pubblicato: 17/01/2023 10:18:15
Sorry Jean but I don't understand what I'm supposed to see. I also get "data - not defined".
data not defined probably indicates some plugins not installed.
Maybe other problems wrt your version.
#83 Pubblicato: 17/01/2023 10:55:42
Here it is.
Document does not open ... incorrect format
#84 Pubblicato: 17/01/2023 11:15:28
German
German
SMath Studio Desktop 64-bit
Version: 1.0(build: 8348)
Date: 9/11/2022
ConditionallyFormattedLabel: 1.0.8138.35454
#85 Pubblicato: 17/01/2023 11:20:05
Gruppo: Moderator
If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error.
The same happens if you try to force a numerical evaluation using eval()
#86 Pubblicato: 17/01/2023 12:05:21
German
German
That is it!
As allways thanks!!
But still don't understand why Jean files fails.
#87 Pubblicato: 17/01/2023 12:12:05
Date: 9/11/2022
Slide left the Formatted Label
Side right the graph, remove the Σ no definido
You should see the plot.
#88 Pubblicato: 17/01/2023 12:15:52
Gruppo: Moderator
That is it!
As allways thanks!!
You're welcome!
There is an excel data import at the begin of the file, is not related to the issue however so it doesn't matter. nevermind I was looking at your file.
If you remove the 3 inline evaluations it will work.
2023-01-17 16_28_05-SMath Solver - [Image Formated LABEL [Oxyhemoglobin] FORUM.sm].png
#89 Pubblicato: 17/01/2023 12:39:57
German
German
My file can be an example of things NOT to do.
#90 Pubblicato: 14/10/2023 23:08:58
Rogalski
Rogalski
0 apprezzamenti in 7 post.
Can we manage the units that are displayed?
I have a load in kN/m2 and the result appears as kg/(m*s2).
The idea is to present only positive values (with the appropriate unit).
kind regards
Conditionally Formatted Labels_unity.sm (5,47 KiB) scaricato 1881 volta(e).
#91 Pubblicato: 14/10/2023 23:52:58
Gruppo: Moderator
The easier way might be something like this
2023-10-14 18_53_23-SMath Solver - [Conditionally Formatted Labels_unity.sm_].png
press2text(x):line(concat(var2str(x/'kPa,1),"\0020\kN\002F\m\00B2\",1,1)
Oscar Campo 15/10/2023 00:41:00
#92 Pubblicato: 15/10/2023 00:08:06
Rogalski
Rogalski
Thank you very much.
This is exactly what I needed.
#93 Pubblicato: 15/10/2023 23:51:23
Rogalski
Rogalski
I'm looking for a way to represent the letter D as a subscript. Unfortunately, Unicode doesn't seem to provide this option...
Is there any possibility to parameterize individual characters that will be presented?
#94 Pubblicato: 16/10/2023 03:06:16
You can subscribe whatever.
mysystem dot HelloGrandMa
#95 Pubblicato: 17/10/2023 01:32:30
Rogalski
Rogalski
thanks for the information, but I'm not sure if I expressed myself correctly. I mean the subscripts in the "phrases" that I marked in the drawing.
Davide sent the function shown above in which I need to use subscripts.
#96 Pubblicato: 17/10/2023 02:13:46
Oscar Campo
Oscar Campo
135 apprezzamenti in 309 post.
Gruppo: Moderator
Davide used superscript unicode character for write: "kN\002F\m\00B2\" wich renders as "kN/m²" so, you can use unicode characters...but not all characters have subscript version.
Please check here: https://www.compart.com/en/unicode/search?q=subscript#characters
Oscar
#97 Pubblicato: 17/10/2023 13:30:37
Hi Karol. This could be a workaround, using the SMath Plot region.
label.sm (6,22 KiB) scaricato 1860 volta(e).
Oscar Campo 17/10/2023 16:52:00
#98 Pubblicato: 17/10/2023 18:15:56
Subscripts in native Solver 30405.
Collect as many the project needs,
call the wanted by indexing.
Maths Subscript.sm (10,73 KiB) scaricato 1884 volta(e).
#99 Pubblicato: 17/10/2023 23:23:29
Rogalski
Rogalski
Wow great Alvaro. Thank you very much.
I'm impressed.
#100 Pubblicato: 17/10/2023 23:26:39
Rogalski
Rogalski
Jean Giraud,
Thank you too.
But I have to put in some effort to understand what you sent.
Kind regards
