Conditionally Formatted Labels
Conditionally Formatted Labels - Add Conditionally Formatted Labels in SMath Studio worksheets - Messaggi
#21 Pubblicato: 05/02/2014 06:28:40
Gruppo: Moderator
Good, nice worksheet
From the smartphone I've missed your first screenshot. If you open and save the file from SMath portable your worksheet should works also with the latest plugin, I'm sorry for the inconvenience
#22 Pubblicato: 17/03/2014 19:42:12
Gruppo: Moderator
UPDATED
(SMath Studio 0.97.5189)
- code updated to fit the new APIs features;
#23 Pubblicato: 27/07/2014 06:52:50
Gruppo: Moderator
UPDATED
- Bug SS-181 fixed;
#24 Pubblicato: 19/09/2014 10:03:45
brotjob
brotjob
7 apprezzamenti in 71 post.
I just lost one day of work because of this plugin. Because it crashes sometimes when entering formatted labels I saved my changes regularly. But now I have a corrupt file, a crash occurs immediately after opening I'm using v0.97 build 5346
#25 Pubblicato: 19/09/2014 10:25:22
Gruppo: Moderator
I'm sorry for that...
can I help you to recover the file? If you can't share it here, send me an e-mail...
I need to know how to reproduce the bug, to fix it... Can you make a simple example and the steps to reproduce the issue?
Davide
edit: the problem occours when a variable is not defined/there's an error message thrown in the placeholder, I'll fix it ASAP.
#26 Pubblicato: 19/09/2014 13:57:06
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.97.5346
- Fixed critical bug on exceptions' propagation;
- APIs updated;
@brotjob: after updating the plugin, your file should be opened also without disabling auto-recalculation.
Вячеслав Мезенцев 19/09/2014 14:42:00, ioan92 19/09/2014 14:26:00
#27 Pubblicato: 22/09/2014 01:55:21
brotjob
brotjob
thank you for helping. The file can be opened again. Will test the new plugin version today.
#28 Pubblicato: 22/09/2014 05:28:01
brotjob
brotjob
There seems to be another issue with conditionally formatted labels:
  1. insert an area
  2. collapse the area
  3. insert a cfl below
  4. mark everything
  5. move everything
What happens is that the cfl does not move in relation to the rest. It can jump inside the area or just below the line of the collapsed area.
#29 Pubblicato: 22/09/2014 05:56:45
Gruppo: Moderator
This seems a bug in the area region...
1) create a new worksheet
2) add an area region
3) collapse it
4) add a text region below the collapsed region, leaving a wide space.
5) select all (using the "select all" option or simply select the collapsed region and the text region)
6a) move all down a little using the mouse, and then do it again -> the space between the text region decreases progressively; when the text is close enough, goes inside the collapsed area region.
6b) move all up a little using the mouse, and then do it again -> the space between the text region decreases progressively and if you expand the area region, the size become larger at each movement; when the text is close enough, goes inside the collapsed area region. The size increase with absorption happens also if you select only the collapsed area.
Both doesn't happens if you use the up/down keys or if the area is not collapsed.
Added in the BTS: SS-221
#30 Pubblicato: 26/09/2014 02:16:13
brotjob
brotjob
The new version disabled the feature if a ("true" "" "") ("false" "" "") I thought this is practical, why remove it? Now I have to use if a>0 ...
Also, when I modify a sheet that was created with an older version of the plugin that uses the old style syntax and I adopt it to the new syntax, Smath Studio crashes. I will try without automatic recalculation now but my data is lost.
#31 Pubblicato: 26/09/2014 03:26:38
Gruppo: Moderator
Hello brotjob,
I cannot reproduce (or I've misinterpreted the issue)
I see what is shown in the screenshot
#32 Pubblicato: 26/09/2014 05:01:29
brotjob
brotjob
Hi Davide
First of all it's nice that you don't need the matrices anymore. Is there some kind of documentation of the plugin?
I tried your above left example in a new worksheet->works perfectly. I change a to 1m ->label becomes red. I change if a to if a>0 ->smath crashes
#33 Pubblicato: 26/09/2014 07:42:31
Gruppo: Moderator
Is a recent feature
The official documentation is attached in the first post, moreover the Activebook of Martin Kraska contains a section for this plugin. Both should be updated, I'll do ASAP.
This is because the if statement doesn't support units as result of the condition argument. This is not in my hands.
I can't reproduce this issue, I'll investigate...
#34 Pubblicato: 26/09/2014 11:20:30
Gruppo: Moderator
Is a recent feature
dexcription updated, please check.
Plugin CF Region.sm (40,43 KiB) scaricato 1676 volta(e).
Davide Carpi 26/09/2014 12:01:00
#35 Pubblicato: 26/09/2014 11:55:03
Gruppo: Moderator
Thank you Martin, checked and solved a couple of minor issues (region disabled in the worksheet) Plugin Updated
Plugin CF Region.sm (40,32 KiB) scaricato 1715 volta(e).
#36 Pubblicato: 26/09/2014 12:15:37
Gruppo: Moderator
Documentation updated (see first post)
Martin Kraska 26/09/2014 12:18:00
#37 Pubblicato: 26/09/2014 12:17:04
Gruppo: Moderator
Ok, thanks, I'll include that in the next update.
Davide Carpi 26/09/2014 12:19:00
#38 Pubblicato: 27/09/2014 16:52:26
Ryan Freund
Ryan Freund
20 apprezzamenti in 339 post.
Surprised I didn't know about this. This is great, thanks.
#39 Pubblicato: 29/09/2014 03:54:52
brotjob
brotjob
The file is great but when I play with the sliders I every so often get a crash... Using plugin version 1.0.5382.30912 and current standalone Smath.
Davide Carpi 29/09/2014 10:38:00
#40 Pubblicato: 29/09/2014 06:35:58
Gruppo: Moderator
Confirmed. The post relates to this file
