Advantage of vectorize function - Data Analysis Using Truth Tables - Messaggi
to find the Standardized Precipitation Index (SPI).
58 years of daily precipitation data was available.
The SPI is widely used to analyze meteorological drought on a range of
time scales. There are proprietary software packages for this purpose.
The “vectorize” function was pretty handy and fast in analyzing various conditions.
SPI_cal-Rev & Improved-Final.sm (1,92 MiB) scaricato 1509 volta(e).
Rainfal_Data.xlsx (486,22 KiB) scaricato 1126 volta(e).
necessary to extract numerical values removing any strings, or
negative values, zeros etc.
Data Analysis Using Truth Table.sm (78,91 KiB) scaricato 1460 volta(e).
WroteAttached file may be useful in handling data, where it may be
Maybe more or otherwise in there.
Utilities Matrix Truth Table.sm (59,54 KiB) scaricato 1457 volta(e).
Utilities Matrix Truth Table [UNSORTED alyles].sm (15,01 KiB) scaricato 1311 volta(e).
Utilities Matrix Truth Table [Locate row_col].sm (43,39 KiB) scaricato 1338 volta(e).
Another practical example attached, with extensive use of the vectorize function. No loops used.
Comments by Martin, Jean, Razonar and others on this subject much appreciated.
Hope this may be useful for beginners.
Cheers
SPI_cal-Millawana_Multiple_R5.sm (178,1 KiB) scaricato 1439 volta(e).
rainfall_KalaOyaBAsin.xlsx (585,15 KiB) scaricato 1090 volta(e).
WroteComments by Martin, Jean, Razonar and others on this subject much appreciated.
Sorry mon Ami ... SS 6179 does not open ... Jean
The data file consists of date strings, and hence, had to be transformed into numeric.
Hope this may be useful for beginners. Vectorize function very useful in this exercise.
Handling DATE STRINGS.sm (16,17 KiB) scaricato 1440 volta(e).
Take care my Friend ... Jean
WroteAttached is a simplified version of a project work for demonstration only.
Hi. Handling data strings you have also this cheat for convert dates to numeric matrices.
Handling DATE STRINGS.sm (20,56 KiB) scaricato 1383 volta(e).
Thank you Razonar for the superb alternative. Take care.
Revised program to handle date strings.
Handling DATE STRINGS+Alvaro.sm (43,62 KiB) scaricato 1425 volta(e).
WroteRevised program to handle date strings.
Thanks Collab for that most useful work.
Saved ... for future use.
Hi Amarasekera. Yes, that one, thanks. The fact you're showing despite to me about the speed in procedures with arrays. In the attached some comments about the need to redefining M:=M where M is a matrix argument in a procedure.
EvalTest.sm (17,47 KiB) scaricato 1412 volta(e).
EvalTest.pdf (73,82 KiB) scaricato 769 volta(e).
As it looks, pure numerical code coincidence as a fact.
Slightly adapted for convenience SS 6179
Thanks, cheers ... Jean
Maths eval(,) TEST.sm (16,84 KiB) scaricato 1401 volta(e).
WroteHi Amarasekera. Yes, that one, thanks. The fact you're showing despite to me about the speed in procedures with arrays. In the attached some comments about the need to redefining M:=M where M is a matrix argument in a procedure.
Alvaro,
Are you showing that by redefining Mo variable, within the program, it speeds it up 30 fold? That makes no sense
The only thing that remotely comes to mind is that M, being defined within the program structure as M:=Mo, is not having to read for the variable from the outside.
Have you, or anyone else, tried this on other programs?
Alvaro,
Are you showing that by redefining Mo variable, within the program, it speeds it up 30 fold? That makes no sense![]()
Yes. Please, try to check in your environment if this is true also. (Notice that my laptop is very slow, because always is running something else or overloaded by some other procedures)
Yes. For this was the issue in the original Amarasekera work, and why I say that he was the first showing this behavior. But I have other codes where using M:=M speed up slow procedures. Actually anything with a loop over a matrix.
Here intermediate timing result, which I can't explain
