Rolling the Torus [under construction]
Rolling the Torus [under construction] - Rolling the Torus [under construction] - Messaggi
#1 Pubblicato: 05/06/2017 22:42:12
... it works, but it must be stopped dancing !
I figure some fixed Euler orientation must be applied ?
Torus.sm (24,31 KiB) scaricato 1334 volta(e).
#2 Pubblicato: 06/06/2017 04:54:19
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
Hello Jean Giraud !
The calculation time will be greatly reduced, if the coordinates are represented as functions
x(t),y(t),z(t).
Torus Mod.sm (27,45 KiB) scaricato 1328 volta(e).
Davide Carpi 06/06/2017 07:25:00
#3 Pubblicato: 06/06/2017 10:06:34
Thanks Ber7 for doctoring !
Orientation is acceptable, ~ 3 minutes visit.
Torus.sm (33,61 KiB) scaricato 1319 volta(e).
Torus Rolling.gif ... updated
#4 Pubblicato: 06/06/2017 14:12:13
Fridel Selitsky
Fridel Selitsky
Good work, Jean. I extended the animation to the full cycle.
Jean Giraud.sm (20,27 KiB) scaricato 1356 volta(e).
Davide Carpi 06/06/2017 16:00:00, Andrey Ivashov 07/06/2017 12:05:00
#5 Pubblicato: 22/09/2017 14:41:02
Fridel Selitsky
Fridel Selitsky
Surface represented by lines.
Jean Giraud2.sm (19,82 KiB) scaricato 1313 volta(e).
