Lagrange Multipliers
Lagrange Multipliers - Lagrange Multipliers - Messaggi
#1 Pubblicato: 22/10/2018 16:52:10
Draghilev is on the menu ... is it applicable in there ?
Maths Lagrange Multipliers Copy.sm (59,81 KiB) scaricato 1297 volta(e).
#2 Pubblicato: 23/10/2018 08:05:41
Hi Jean. Yes, it is ... but just give only one point, because there are only one solution. And the method requires at least one starting point ...
Drag_Jean.pdf (54,46 KiB) scaricato 825 volta(e).
Drag_Jean.sm (49 KiB) scaricato 1338 volta(e).
#3 Pubblicato: 23/10/2018 18:06:21
Maximization added.
Drag_Jean max and min.pdf (76,37 KiB) scaricato 820 volta(e).
Drag_Jean max and min.sm (56,51 KiB) scaricato 1240 volta(e).
#4 Pubblicato: 23/10/2018 23:18:35
Maximization added.
Thanks Alvaro ... gorgeous solutions.
The Draghilev part persists "Syntax incorrect".
Don't worry Alvaro: You are doing so much for Smath Community !!!
Maths Lagrange Multipliers Alvaro [Maximize-Minimze] Copy.sm (23,64 KiB) scaricato 1180 volta(e).
