1 страниц (4 вхождений)
Lagrange Multipliers - Lagrange Multipliers - Сообщения
Draghilev is on the menu ... is it applicable in there ?
Maths Lagrange Multipliers Copy.sm (59,81 КиБ) скачан 1292 раз(а).
WroteDraghilev is on the menu ... is it applicable in there ?
Hi Jean. Yes, it is ... but just give only one point, because there are only one solution. And the method requires at least one starting point ...
Drag_Jean.pdf (54,46 КиБ) скачан 819 раз(а).
Drag_Jean.sm (49 КиБ) скачан 1332 раз(а).
Maximization added.
Drag_Jean max and min.pdf (76,37 КиБ) скачан 815 раз(а).
Drag_Jean max and min.sm (56,51 КиБ) скачан 1236 раз(а).
WroteMaximization added.
Thanks Alvaro ... gorgeous solutions.
The Draghilev part persists "Syntax incorrect".
Don't worry Alvaro: You are doing so much for Smath Community !!!
Maths Lagrange Multipliers Alvaro [Maximize-Minimze] Copy.sm (23,64 КиБ) скачан 1175 раз(а).
