Length of a Matrix
Length of a Matrix - Messaggi
#1 Pubblicato: 27/02/2019 20:41:15
Hi. Is this the expected behavior?
Append.sm (6,87 KiB) scaricato 1424 volta(e).
I hope not. I expect A' = [1 2 3 4]
#2 Pubblicato: 27/02/2019 21:32:07
Alvaro: maybe like this ?
#3 Pubblicato: 27/02/2019 21:53:45
Hi Jean. Nope, maybe more like this:
BTW, this is a workaround. I expect this result but for the previous syntax.
#4 Pubblicato: 27/02/2019 22:20:41
You just append, my code inserts wherever needed.
My mistake I named Append(,,,)
OK, you are imitating MCD.
Simpler Append: transpose the row, stack, re-transpose.
#5 Pubblicato: 27/02/2019 22:25:09
I'm trying to imitate Wolfram's Mathematica Append.
#6 Pubblicato: 28/02/2019 01:59:51
Not that much miraculous Mathematica 4.0
Mathcad APENDPRN was almost never used.
Useful to compact/file a data set with wisely
collected the fitting coefficients.
On that application, Smath is far superior ... Explain
Smath can save same stuff + the formula ... WOW !
Saludad Alvaro [is that correct ?]
Page24 Alvaro.sm (15,01 KiB) scaricato 1745 volta(e).
#7 Pubblicato: 28/02/2019 05:48:34
Gruppo: Moderator
Yes it is correct, or at least it conforms with the general approach of the program (vectors are single column matrices, anything else is a matrix). You might see it better in a 2 rows matrix:
The new indices are added expanding the matrix vertically; there is no special case for single-row matrices.
For your task, one way could be this:
Or this:
frapuano 28/02/2019 06:06:00, Alvaro 28/02/2019 06:07:00, NDTM Amarasekera 28/02/2019 12:13:00
#8 Pubblicato: 28/02/2019 13:22:34
#9 Pubblicato: 28/02/2019 14:42:13
... append this Jacobian matrix.
#10 Pubblicato: 28/02/2019 15:05:51
Close. Correct it's Saludos Jean.
Thanks for the explain. You give to me the rule for understand the result. Just as comment, matlab don't follow that, and gives this results:
File non trovato. File non trovato.
#11 Pubblicato: 01/03/2019 01:03:18
What Matlab does Smath does as well with lot more user specifics.
Matlab => MDA [Muliti Dimensional Array]
Mathematica => Cell Array
They just have their system. I can do whatever from this example
and very quick too, just few more modules.
