1 pagine (11 elementi)
Ode symbolic solution with IC - How to solve? - Messaggi
WroteSee please one ODE symbolic solution without IC
We have it done for exporting formula c/w constants & IC
ODE_Laplace 2nd [Type 3].sm (34,42 KiB) scaricato 1217 volta(e).
Valery Ochkov 01/07/2023 09:20:00
WroteWroteSee please one ODE symbolic solution without IC
Thanks!
But no way to do so in SMath
WroteWroteThanks!
"L & m" are missing in dsolve result ?
m is missing in dsolve.
Hi Valery. Use Ctrl+Shift+K for write D(x)(0), which means x'(0)
Thanks!
dsolve-ICs.sm (10,61 KiB) scaricato 1530 volta(e).
The distance between the cities added.
GravityTrain.sm (31,01 KiB) scaricato 1449 volta(e).
GravityTrain.pdf (233,1 KiB) scaricato 925 volta(e).
Valery Ochkov 03/07/2023 04:18:00
Earth distance companion added.
Sanity check Air Industry.
Angle Vincenty Earth Distance [Mike].sm (49,78 KiB) scaricato 1214 volta(e).
WroteA pendulum ...
The exact solution needs some handwrite work.
Edited: a hard handwrite work. Previous version was wrong.
Correct solution -> pendulum v2.sm (13,73 KiB) scaricato 1462 volta(e).
Wrong solution -> pendulum.sm (13,88 KiB) scaricato 1468 volta(e).
Valery Ochkov 05/07/2023 06:23:00
