plotting circle does not work
plotting circle does not work - Help - Messaggi
#1 Pubblicato: 13/03/2022 10:52:33
Blackbambi
Blackbambi
0 apprezzamenti in 3 post.
I am trying to plot mohr's circle by following tutorial. I have succeeded to draw circle on the tutorial but not mine.
Could you check my plot?
Thank you.MSS_Failure criterion.sm (8,47 KiB) scaricato 1305 volta(e).
#2 Pubblicato: 13/03/2022 11:47:06
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
One way to build a graph is to lower the order of large numbers
Primer.sm (8,51 KiB) scaricato 1238 volta(e).
#3 Pubblicato: 13/03/2022 12:32:01
Gruppo: Moderator
You can make a function to draw circles, for multiple usage on same sheet.
With respect to Ber7, dividing it to MPa will lower the numbers too.
MSS.sm (7,3 KiB) scaricato 1279 volta(e).
#4 Pubblicato: 13/03/2022 22:37:25
Blackbambi
Blackbambi
Thank you all. I appreciate your help
#5 Pubblicato: 14/03/2022 13:06:17
Gruppo: Moderator
Here is a version with pre-defined geometric object in the XY plot plugin. See Handbuch section 8.3.4.
MSS_Kr.sm (13,86 KiB) scaricato 1278 volta(e).
#6 Pubblicato: 14/03/2022 14:11:02
Circle de Mohr.sm (47,02 KiB) scaricato 1280 volta(e).
#7 Pubblicato: 15/03/2022 04:28:27
Blackbambi
Blackbambi
Thank you for sharing your work
#8 Pubblicato: 15/03/2022 09:42:51
There are many ways to plot circles wrt applications.
My most used brew ... Cheers, Jean.
Page4 Circles_Ellipses.sm (9,36 KiB) scaricato 1432 volta(e).
#9 Pubblicato: 15/03/2022 13:22:17
Gruppo: Moderator
It is much easier to draw circles with X-Y Plot plugin.
circle_xy.sm (5,23 KiB) scaricato 1340 volta(e).
#10 Pubblicato: 20/03/2022 15:38:42
My most used brew
I prefer incremental discretizer.
Circle [QUICK,oblate_prolate].sm (14,23 KiB) scaricato 1081 volta(e).
