Root or others solver - Messaggi
I cannot solve the system of equation by all the alpha values from 0 too 360 deg.
Is there the better solver for this task?
Or the better way for the solution.
Chebyshevs-Foot-Stepping-Machine.sm (179,44 KiB) scaricato 1522 volta(e).
Chebyshevs-Foot-Stepping-Machine_b.sm (176,63 KiB) scaricato 1481 volta(e).
WroteYour expressions for (x4, y4) were unnecessarily complicated. See attached (Also with a better initial guess for x0).
I'm sorry, but this is not correct. The coordinates of point 4 should depend on the length L.04.
WroteWroteYour expressions for (x4, y4) were unnecessarily complicated. See attached (Also with a better initial guess for x0).
Because L.04 is the same length as L.03 it does, in fact, implicitly depend on L.04. Check the two files for a few angles and you will see that they give the same results (except that my file works for all angles).
Basically, I've used the fact that (x4 + x3)/2 = x0 and (y4 + y3)/2 = y0.
If L.04 and L.03 are different lengths a weighted average would be used, i.e. (L.03*x4 + L.04*x3)/(L.03 + L.04) = x0 and (L.03*y4 + L.04*y3)/(L.03 + L.04) = y0.
See? please the attach
Chebyshevs-Foot-Stepping-Machine.sm (178,3 KiB) scaricato 1487 volta(e).
Now I will try to plot the trac of the point 4.
Help me please.
WroteThanks!
Help me please.
See attached (but I'll leave you to do any animation!).
Chebyshevs-Foot-Stepping-Machine_c.sm (176,97 KiB) scaricato 1488 volta(e).
See please my little editing
Chebyshevs-Foot-Stepping-Machine-Trace.sm (177,86 KiB) scaricato 1481 volta(e).
One question
See please
Chebyshevs-Foot-Stepping-Machine-Trace-Plot.sm (178,15 KiB) scaricato 1509 volta(e).
and tell me - it is my or SMath bug with the plot?
WroteThanks!
One question
See please
?? I don't see anything wrong with the plot!
See please
Oh!, I see! Just double-click on the plot, select Traces, then for each of Traces 2 through 6 select Symbol style, then Circle.
See please
it's one bug?
The chapter 8 from the book
2^5 Problems for STEM Education
Now I am writing same chapter for the SMath book.
For me will be interesting your remarks.
WroteЯ суслика не вижу, можно поконкретнее описать и показать что не так с компонентом X-Y Plot?
Спасибо, Вячеслав, что откликнулся.
Суслик вот в чем.
На этом графике в его аргументе записана система с перечислением кривых.
Chebyshevs-Foot-Stepping-Machine-Trace.sm (177,86 KiB) scaricato 1476 volta(e).
Все ОК.
Затем для компактности документа я захотел использовать переменную Plot.
Формат графика сбился.
См. картинку наверху и
Chebyshevs-Foot-Stepping-Machine-Trace-Plot.sm (178,15 KiB) scaricato 1470 volta(e).
Настройки не должны слетать, если количество графиков между пересчётами документа не меняется. Если возникла ошибка во время построения одного из графиков, то настройки сохраняются. Если вы изменили количество отображаемых графиков (а оно определяется только во время пересчёта), то остальные графики "забываются".
Рекомендация: отключить автоматический пересчёт на время подобных манипуляций.
Я подумаю о добавлении опции - сохранять настройки между пересчётами не только для исключительных ситуаций. Возможно была причина, по которой я оставил такое поведение.
WroteЯ попробовал и мне трудно было повторить условия возникновения такого поведения.
Спасибо!
Заодно подумайте и о:
1. После ввода выражения кривой видно весь график. А то приходится долго крутить мышкой.
2. Возможность фиксирования разброса графика так, чтобы его мышкой нельзя было менять.
http://razdvizh.site/chebl
WroteЯ написал статью о лямбда-механизе Чебышёва. Smath почему-то анимацию не воспроизводит. Могу ответить на вопросы по вычислениям и системе. Решение получено при помощи метода Драгилева.
Спасибо за ценную информацию, но ссылка не работает
Now we can change variables r, L,01, L.02 etc and no problem!
16-4-Chebyshevs-Foot-Stepping-Machine-Trace-Newton.sm (930,96 KiB) scaricato 1597 volta(e).
