exponential function error
exponential function error - Result is above the max. allowed positive number error - Messaggi
#1 Pubblicato: 09/08/2019 08:17:45
MSL
MSL
1 apprezzamenti in 22 post.
Dear masters,
I'got the error, "Result is above the max. allowed positive number error" during exponential calculation.
How I resolve this kind of errors?
Thank you!
M.S.
my error
exponential_max_err_v0.sm (12,83 KiB) scaricato 1164 volta(e).
#2 Pubblicato: 09/08/2019 10:09:38
... like this: index 'j' to de-confuse 'i' imaginary.
exponential_max_err_v0.sm (12,26 KiB) scaricato 1155 volta(e).
#3 Pubblicato: 10/08/2019 00:44:37
Dear masters,
Hi. Summatorie ranged have some issues. For instance, the range variable isn't local. With eval you can get punctual results, but this version can't be plotted, and I don't know why:
Whith this other version you can do both things:
Hope that this helps.
exponential_max_err_v0.sm (13,37 KiB) scaricato 1206 volta(e).
#4 Pubblicato: 10/08/2019 09:08:37
... more doctoring in the *.sm attached
1. local definition mode
2. index piece wise
exponential_max_err_v0 (1).sm (24,22 KiB) scaricato 1181 volta(e).
#5 Pubblicato: 10/08/2019 09:39:30
... code this to the previous doctored document.
Summation operator is very capricious, but works
and plot scalar as demonstrated. Plot scalar for
lot more involved stuff [Budapest 39, Legendere ...]
Remember Alvaro: you doctored my Barnes Hypergeometric !
#6 Pubblicato: 12/08/2019 23:43:12
MSL
MSL
Thank you your replies.
But I have a still same problem.
Here are another sample file.
exponential_max_err_v03.sm (18,91 KiB) scaricato 1186 volta(e).
#7 Pubblicato: 13/08/2019 01:08:10
Hi. Yes, it's hard to drive those calculations. Try to avoid sum(1) too:
MSL 13/08/2019 11:09:00
#8 Pubblicato: 13/08/2019 04:13:24
alisonparker
alisonparker
0 apprezzamenti in 2 post.
Dear masters,
Thank you!
M.S.
my error
I am getting error "Result is above max allowed positive number",too! And l don't know how to solve it.Function error
#9 Pubblicato: 13/08/2019 04:35:54
Gruppo: Moderator
I think something is wrong here in the numeric/symbolic engine of SMath which causes those errors.
Version "0.99.7109"
I can not understand this . The error message is quite confusing. The result is quite a small number close to zero. On the other hand, by mouse hoovering the vector it could be seen the fraction presentation of the numbers (symbolic engine) with quite large numbers in the denominator. Therefore the message about max. allowed positive numbers. I think something is wrong in the floating point arithmetic in SMath numerical engine or at least quite problematic. It seems that eval() must be used extensively in order to escape from these traps and to avoid the symbolic engine to make a mess here.
#10 Pubblicato: 13/08/2019 09:49:55
But I still have same problem.
Hello Novice ...
I can't see what you are attempting.
Are you trying to fit a model function to a data set ?
If so: just attach the data set, some smart cat will exercise.
A maths document that has no hint about ... Oh !
#11 Pubblicato: 13/08/2019 11:03:24
Version "0.99.7109"
From observation in many more SS 7109, the indexing is freaked.
Doctored in pink SS 6179.
exponential_max_err_v03.sm (17,79 KiB) scaricato 1154 volta(e).
#12 Pubblicato: 13/08/2019 11:08:02
MSL
MSL
Dear jean,
I'm just doing the calculation of an ANS standard example.
I think this problem is a kind of overflow of exponential function.
As you know if X is greater than the 709.783 then the value of exp(X) is overflown.
So I believe that SMath should do something to check the nominal boundaries of special functions (exponential, logarithmic etc.)
Thank you!
regards,
MS
#13 Pubblicato: 13/08/2019 11:34:52
Thank you!
Thanks for the hint.
Functions that overflow can be managed otherwise.
About that project, just give the X,Y data you want to fit.
Smath reports overflow as "max value ..."
All those math functions aren't Smath, rather from numerical library
as implemented in Microsoft and other maths tools.
Ah! I can see XY pairs coming soon.
#14 Pubblicato: 13/08/2019 13:08:21
Gruppo: Moderator
Version "0.99.7109"
Still confused...
exponential_max_err_v03-corr.sm (31,47 KiB) scaricato 1185 volta(e).
#15 Pubblicato: 13/08/2019 16:19:16
Still confused...
Doctored a bit SS 6179 ... No red in No time.
exponential_max_err_v03-corr.sm (32,81 KiB) scaricato 1168 volta(e).
#16 Pubblicato: 13/08/2019 17:03:20
... from there => what's next step ?
exponential_max_err_v03-corr [Next].sm (39,26 KiB) scaricato 1026 volta(e).
#17 Pubblicato: 13/08/2019 21:27:11
... from there what's next =
... does the suite in green makes sense ?
That mystic formula has to be put in executable maths
exponential_max_err_v03-corr [Next-Suite].sm (160,47 KiB) scaricato 1080 volta(e).
#18 Pubblicato: 14/08/2019 01:17:41
Please, check my interpretation.
exponential_max_err_v03-corr [Next-Suite].sm (185,37 KiB) scaricato 1015 volta(e).
#19 Pubblicato: 14/08/2019 03:20:01
Gruppo: Moderator
Still confused...
Still red for me...
#20 Pubblicato: 14/08/2019 10:04:59
Still red for me...
Radovan, mon ami ... you must feel Sysyphus on that boulder !
I figure the all project is as simple as in the attached SS 6179.
Novice didn't give enough ... wait and see.
On the other hand your red is for Grand Doctor Andrey.
Fission.sm (133,59 KiB) scaricato 1131 volta(e).
