1 pagine (3 elementi)
import .xmcd files - .xmcd problem - Messaggi
I have several files converted by mathcad from .mcd to .xmcd but they 'won't parse' correctly in smath. Help
I am having a similar issue. It has to do with elements of a martix defined in Mathcad that won't come across to SMath. The original Mathcad file defines individual elements of a array and a matrix that won't translate. I can define them the same way inside SMath. Is this a bug, or has this type of definition not been programmed to import yet?
WroteI am having a similar issue. It has to do with elements of a martix defined in Mathcad that won't come across to SMath. The original Mathcad file defines individual elements of a array and a matrix that won't translate. I can define them the same way inside SMath. Is this a bug, or has this type of definition not been programmed to import yet?
Could be a bug, an unknown inconsistence between Mathcad and SMath Studio or a lack...
However without an attached file that contain the cause of the issues it's not easy to understand where is the bug (this is refered also for the first post)
regards,
w3b5urf3r
