import .xmcd files
import .xmcd files - .xmcd problem - Сообщения
#1 Опубликовано: 16.02.2013 13:02:57
Scott Caples
Scott Caples
I have several files converted by mathcad from .mcd to .xmcd but they 'won't parse' correctly in smath. Help
#2 Опубликовано: 24.02.2013 23:27:33
Chris K
Chris K
I am having a similar issue. It has to do with elements of a martix defined in Mathcad that won't come across to SMath. The original Mathcad file defines individual elements of a array and a matrix that won't translate. I can define them the same way inside SMath. Is this a bug, or has this type of definition not been programmed to import yet?
#3 Опубликовано: 25.02.2013 13:32:58
1 438 сообщений из 2 924 понравились пользователям.
Could be a bug, an unknown inconsistence between Mathcad and SMath Studio or a lack...
However without an attached file that contain the cause of the issues it's not easy to understand where is the bug (this is refered also for the first post)
regards,
w3b5urf3r
