2D Plots
2D Plots - What am I missing? - Messaggi
#1 Pubblicato: 25/10/2021 13:34:04
Lloyd Snell
Lloyd Snell
0 apprezzamenti in 8 post.
Trying to plot a variety of functions and nothing shows up in the plots.
I have 23 yrs of MathCad experience, but cannot figure out what Smath is looking for to plot three very simple function (See attached file).
Additionally, I am not sure why an equation needs vectorized to output the answers in the normal distribution equation.
Equation 1 - Normal distribution does not solve as a function until it is vectorized. Why?
Equation 2 - f(x):x^3+2*x*sin(0.25) solves without vectorization but will not plot. Why?
Equation 3 - f(x):vectorize(1/{σ*sqrt(2*π)}*e^{-1/2*({x-μ}/σ)^2}) solves with vectorization but does not plot (2D or X-Y plot method). Why?
Smath - 2D Plots.sm (15,56 KiB) scaricato 1230 volta(e).
#2 Pubblicato: 25/10/2021 13:54:36
Lloyd Snell
Lloyd Snell
Equation 2 also needs vectorized to get the correct results.
You don't have to do this in MathCad, why here?
#3 Pubblicato: 25/10/2021 14:35:07
127 apprezzamenti in 342 post.
You have defined a vector of values ​​for x. If you use the X-YPLOT plugin you need to change the variable. If instead you use SM native 2D graph then it already works as you expect
#4 Pubblicato: 25/10/2021 14:42:14
Lloyd Snell
Lloyd Snell
First Solution Found
This allowed me to plot Normal Distribution Function.
augment(x,f(x))
#5 Pubblicato: 25/10/2021 15:13:13
Lloyd Snell
Lloyd Snell
Solved for now. On with the learning experience.
Thanks....
#6 Pubblicato: 25/10/2021 15:13:44
Renzo Choque
Renzo Choque
6 apprezzamenti in 18 post.
Hi, if you need a quick plot I recommend you use 2D standard plot you can plot functions f(x) directly , if you need a more configurable plot use XY plot but you need to put your data in a special format. File non trovato.File non trovato.
#7 Pubblicato: 25/10/2021 15:29:09
Gruppo: Moderator
You don't need to use range() and augment() if you want to plot sections.
You can limit it with if-else() or cases().
#8 Pubblicato: 25/10/2021 15:43:24
1. Show the two other ones on same document for doctoring.
2. Your sigma makes no sense !
3. BTW, in Samples you should find my Stat Treasury [10 WS]
Hard to find such immense Compendium.
4. If you can't download, please let me know
Welcome ... Jean.
Smath - 2D Plots.sm (17,77 KiB) scaricato 1234 volta(e).
#9 Pubblicato: 25/10/2021 15:50:14
... besides the pure statistical application,
you can use to fit data sets [Fréchet US Rainfall ...]
#10 Pubblicato: 25/10/2021 15:52:41
There is about 24 built-in PDF in Smath ... f(x) menu
as well as CDF, ICDF
#11 Pubblicato: 26/10/2021 07:05:13
1. Discretize the range you want and plot ... No vectorize.
2. Plot scalar directly.
#12 Pubblicato: 26/10/2021 07:29:00
Paecific.sm (9,62 KiB) scaricato 1239 volta(e).
#13 Pubblicato: 26/10/2021 08:20:56
... in most applications inc(Low,High,step,f(#)) is preferred
Paecific.sm (14,25 KiB) scaricato 1267 volta(e).
#14 Pubblicato: 26/10/2021 09:50:27
Scalar plots have limited use, mostly confirm the project.
Discrete plot can be used for subsequent application/export.
1. Collapsed the algo at top utilities.
2. Use it infinitely in-situ use [range each f(x) at will].
#15 Pubblicato: 26/10/2021 11:29:10
Gruppo: Moderator
Try this file.
Smath - 2D Plots_r1.sm (17,22 KiB) scaricato 1283 volta(e).
File non trovato.
