1 pagine (8 elementi)
list calculation - list calculation - Messaggi
I have just submitted a book on Engineering Mechanics with SMath Studio for publishing. It is to appear early next year. The examples are already available at Github https://github.com/sn-code-inside/Technische-Mechanik-mit-SMath.
See example 5.5.
See example 5.5.
Modificato 07/12/2025 17:19:11
5 utenti hanno apprezzato questo post
sergio 07/12/2025 16:48:11, Alvaro 08/12/2025 08:52:29, Davide Carpi 08/12/2025 10:42:01, ioan92 12/04/2026 09:56:46, kimkim 07/12/2025 14:32:30
Martin, the link you posted mistakenly incorporates the GitHub string at the beginning, nullifying the connection; you should correct it.
Sergio, I can't reproduce the problem. In both instances where I posted the link, it works in my browser. Also, I see some traffic on Github today, so that I expect the link to work for others as well.
As a backup, here is the plain text link: https://github.com/sn-code-inside/Technische-Mechanik-mit-SMath
Modificato 07/12/2025 22:41:04
sergio 08/12/2025 14:31:34
It was me who corrected the link.
For structural analysis in SMath, using vectors usually works out much better than lists anyway, especially when you start dealing with larger matrices or displacement vectors. It keeps the math a bit cleaner and more consistent with how SMath handles calculations internally. That Engineering Mechanics book example looks like a great resource to keep on hand for these types of workflows too!
