list calculation
list calculation - list calculation - Сообщения
#1 Опубликовано: 07.12.2025 06:52:39
kimkim
kimkim
0 сообщений из 9 понравились пользователям.
Hi~ I'm studyng building structural analysis.
When I calculate the displacement, I have to use list calculation like below using Ti nspire.
I would try this way in smath studio, but failed.
How can I calculate in smath studio?
thank you for your help.
#2 Опубликовано: 07.12.2025 09:23:36
StvMath
StvMath
44 сообщений из 71 понравились и 1 не понравились пользователям.
The following uses vectors rather than lists:
You beat me to it by seconds!
Отредактировано 07.12.2025 09:24:32
kimkim 07.12.2025 14:32:35
#3 Опубликовано: 07.12.2025 09:29:24
kimkim
kimkim
Thank you, StvMath.
I've just found the solution, but I think your way is more efficient than mine !!
Thank you again.
Отредактировано 07.12.2025 09:29:46
#4 Опубликовано: 07.12.2025 12:34:43
I have just submitted a book on Engineering Mechanics with SMath Studio for publishing. It is to appear early next year. The examples are already available at Github https://github.com/sn-code-inside/Technische-Mechanik-mit-SMath.
See example 5.5.
Отредактировано 07.12.2025 17:19:11
sergio 07.12.2025 16:48:11, Alvaro 08.12.2025 08:52:29, Davide Carpi 08.12.2025 10:42:01, ioan92 12.04.2026 09:56:46, kimkim 07.12.2025 14:32:30
#5 Опубликовано: 07.12.2025 16:54:33
Martin, the link you posted mistakenly incorporates the GitHub string at the beginning, nullifying the connection; you should correct it.
#6 Опубликовано: 07.12.2025 22:39:12
Sergio, I can't reproduce the problem. In both instances where I posted the link, it works in my browser. Also, I see some traffic on Github today, so that I expect the link to work for others as well.
As a backup, here is the plain text link: https://github.com/sn-code-inside/Technische-Mechanik-mit-SMath
Отредактировано 07.12.2025 22:41:04
sergio 08.12.2025 14:31:34
#7 Опубликовано: 08.12.2025 09:21:48
1 555 сообщений из 1 867 понравились пользователям.
It was me who corrected the link.
sergio 08.12.2025 14:31:35, Martin Kraska 08.12.2025 11:10:15
#8 Опубликовано: 12.04.2026 07:23:00
Norrah_Casper
Norrah_Casper
For structural analysis in SMath, using vectors usually works out much better than lists anyway, especially when you start dealing with larger matrices or displacement vectors. It keeps the math a bit cleaner and more consistent with how SMath handles calculations internally. That Engineering Mechanics book example looks like a great resource to keep on hand for these types of workflows too!
