DISCARDED: SMath Studio 0.99.6647 (14 March 2018) - Messaggi
Offre numerose funzionalità di calcolo e un'interfaccia utente ricca, tradotta in circa 40 lingue diverse. L'applicazione include inoltre un prontuario matematico integrato.
L'applicazione può essere facilmente estesa in base alle proprie esigenze. Lo strumento integrato "Gestione estensioni" consente di accedere a centinaia di risorse, sia ufficiali che di terze parti, tra cui: esempi d'uso, plug-in, applicazioni basate su SMath Viewer, frammenti di codice, traduzioni dell'interfaccia, libri interattivi, manuali e tutorial.
Download
SMathStudioDesktop.0_99_6647.Mono.tar.gz (1,28 MiB) scaricato 2509 volta(e).
SMathStudioDesktop.0_99_6647.Setup.msi (2,15 MiB) scaricato 4747 volta(e).
SMathStudio 0.99.6646 and 0.99.6647 discarded due to serious bug with colapsed areas, which could damage your worksheet data.
Sorry for inconvenience. Working to fix it asap!
WroteuMath Files Plugin appears to be broken with new release.
Thank you! Fixed and new plug-in version uploaded.
Thanks,
Jason
WroteArea controls seem to have been adversely affected with this build.
Please could you send a file to me by e-mail to fix? I cannot reproduce this issue on any of my worksheets.
In my case, when the sheet is opened, the problem does not exist but after saving the sheet, after closing it and finally reopening, problems with the collapsed areas occur.
C6 Channel Shear Tab.sm (228,91 KiB) scaricato 1669 volta(e).
Do you have the initial version?
WroteI experienced problems similar to those of Jason.
Sergio, seems this is very important issue. And bug is in saving logic.
Please could you provide any file which gives this error on save?
Thanks in advance!
Jason
Channel Shear Tab.sm (228,88 KiB) scaricato 1629 volta(e).
I've reproduced this issue and it is introduced exactly in 0.99.6646.
I'm working to figure out the reason and fix it asap.
The following SMath Studio nightly builds are marked as NOT APPROVED and will not be suggested to download to anyone anymore: 0.99.6646, 0.99.6647!
Thank you very much for the report and your help!
