if_else Exception Report
if_else Exception Report - if_else Exception Report - Messaggi
#1 Pubblicato: 11/04/2019 10:21:35
Can't make it work ... SS 6179
Please, can you quick verdict: NOT compatible
or if possible doctor the patient ?
It may have to be constructed recursive style
Thanks in advance ... Jean
Spline Bspline FAILS.sm (66,5 KiB) scaricato 1456 volta(e).
#2 Pubblicato: 11/04/2019 12:57:17
Arie
Arie
94 apprezzamenti in 285 post.
Here's something that at least evaluates on 0.99.7030. One thing to note about your function.
There isn't a "return" statement in Smath programming. A program returns the last line entry by default. So to compensate, you have to assign values to a variable and pass that variable at the end. In this case I chose "ans".
I also used "cases" function to clean things up a bit.
Spline Bspline PASSES-alyles.sm (68,51 KiB) scaricato 1399 volta(e).
#3 Pubblicato: 11/04/2019 13:36:28
Arie
Arie
I had an error some of the logic. Also updated to mimic graph that was attached.
Spline Bspline PASSES-alyles.sm (79,56 KiB) scaricato 1410 volta(e).
Spline Bspline PASSES-alyles.pdf (266,43 KiB) scaricato 926 volta(e).
#4 Pubblicato: 11/04/2019 14:28:15
Thanks Grand Doctor Alyles ... works fine.
Will refresh soon ... Jean
