1 pagine (10 elementi)
Fractal Tree - a programme for displaying a fractal tree - Messaggi
I have created a programme to display a fractal tree in a 2D plot.
fractal tree.sm (7,93 KiB) scaricato 1396 volta(e).
fractal tree.pdf (209,83 KiB) scaricato 863 volta(e).
I would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Can anyone give me any pointers on how to do it?
If that is not possible, how would the animation be done after all the plot points are calculated?
Thank you
Gerard Bush
Thank you
Gerard Bush
Davide Carpi 16/03/2020 12:19:00
WroteI would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Like this ... in ½ points.
fractal tree.sm (11,31 KiB) scaricato 1386 volta(e).
... hard to size the animation plot canvas.
Otherwise renders well ½ length ... greedy 1533 frames !
Search "Samples"... "Pattern" for lot more.
If you can't find and want more: please ask for.
Pattern fractal tree.sm (17,6 KiB) scaricato 1323 volta(e).
Thank you Jean,
That is just what I was looking for.
To reduce the number of points, and reduce the calculation time the minimum length can be increased. For example, change 'if lenght > 0.25' in the tree function to 'if length > 1.0'. I guess this could even be defined as a variable.
Cheers,
Gerard
Pattern fractal tree.sm (18,39 KiB) scaricato 1323 volta(e).
Cheers,
Gerard
In the program Jean I added the growth of the tree
Pattern fractal 1.sm (12,54 KiB) scaricato 1327 volta(e).
5 utenti hanno apprezzato questo post
Davide Carpi 16/03/2020 12:19:00, Alvaro 17/03/2020 16:15:00, Вячеслав Мезенцев 16/03/2020 13:59:00, frapuano 16/03/2020 09:35:00, Gerard Bush 16/03/2020 10:55:00
WroteThat is just what I was looking for.
Few more attached ... Search Julia, Mandelbrot in Forum.
Pattern Koch.sm (11,2 KiB) scaricato 1339 volta(e).
Pattern Frieze Heppi.sm (11,97 KiB) scaricato 1360 volta(e).
Pattern Hilbert.sm (8,53 KiB) scaricato 1311 volta(e).
Pattern Patch Work.sm (10,92 KiB) scaricato 1349 volta(e).
Pattern Fractal Sierpinski.sm (10,92 KiB) scaricato 1378 volta(e).
Pattern Snail.sm (26,85 KiB) scaricato 1359 volta(e).
Pattern Fern.sm (19,4 KiB) scaricato 1369 volta(e).
Pattern Sierpinski Kover.sm (16,72 KiB) scaricato 1348 volta(e).
Pattern Etoile Magic [Short].sm (46,69 KiB) scaricato 1147 volta(e).
Pattern Sierpinski Triangles.sm (35,21 KiB) scaricato 1332 volta(e).
Pattern Prototile.sm (116,5 KiB) scaricato 1412 volta(e).
Pattern PythagorasTree.sm (6,99 KiB) scaricato 1381 volta(e).
Hello Gerard ! ... today, I have cut the tree for You.
Pattern fractal tree [CUT].sm (11,03 KiB) scaricato 1131 volta(e).
Gerard Bush 18/03/2020 09:56:00
Thank you very much, Jean and Ber7 for your additions!
Davide Carpi 18/03/2020 15:07:00, Gerard Bush 18/03/2020 16:59:00, NDTM Amarasekera 19/03/2020 06:03:00
