Program for Linear and Polynomial Fit
Program for Linear and Polynomial Fit - Messaggi
#21 Pubblicato: 11/12/2019 13:31:21
Martin_B
Martin_B
22 apprezzamenti in 84 post.
Hope this document will tranquilize visitors/users !
Jean.
If that's what you think.
#22 Pubblicato: 11/12/2019 19:05:16
Does it work for you ... SS 7251 users please confirm ?
#23 Pubblicato: 11/12/2019 21:25:41
CBG
CBG
78 apprezzamenti in 312 post.
Hello Jean
Yes, It works
Carlos
#24 Pubblicato: 12/12/2019 00:09:00
NDTM Amarasekera
NDTM Amarasekera
130 apprezzamenti in 352 post.
Originally Posted by: MarB [url=/forum/yaf_postsm60156_Program-for-Linear-and-Polynomial-Fit.aspx#post60156][/url]If that's what you think.
It works. Thank you MarB.
#25 Pubblicato: 12/12/2019 07:41:20
NDTM Amarasekera
NDTM Amarasekera
That's my solution
- to separate the functions from matrix building,
- to use vectorize for speed
Apparently, the function f(#x):=1 if n=0 has a problem?. Or is it redundant?
For values n>0, the "otherwise" condition yields correct results irrespective of values in "if" condition.
Please check.
#26 Pubblicato: 12/12/2019 07:53:51
Martin_B
Martin_B
just put the 1 into a 1x1 matrix. That's all.
(And if you want to use units with the X Vector, just remove the eval and evaluate symbolically.)
That's my solution
Please check.
#27 Pubblicato: 12/12/2019 10:21:08
NDTM Amarasekera
NDTM Amarasekera
Hi
Still the same error when n=0.
Better if you can post the SM file please.
#28 Pubblicato: 12/12/2019 11:21:42
Martin_B
Martin_B
Sorry, I didn't realize, that vectorize behaves unexpectedly (to me), when the function does not include 'x'.
So I changed f to f(x):=[1+0*x] and now it works. The file is attached.
PolyFit.sm (11,92 KiB) scaricato 1274 volta(e).
I would expect the results of g and h to be the same, and to be a 3 items long vector.
sergio 12/12/2019 16:13:00
#29 Pubblicato: 12/12/2019 11:49:54
NDTM Amarasekera
NDTM Amarasekera
Hi
Now I get same results as yours.
But the result (19.0833) of the Polyfit() function when n=0 ----> Does it have any meaning?
I have no idea. I was only testing it for all possible conditions..
Cheers MarB.
Note: Incidentally, 19.0833 happens to be the Mean of Y vector.
#30 Pubblicato: 12/12/2019 13:06:39
IMHO ... no need to complicate matters.
Modular design is easier to fix.
More automated is OK if you intend to poly for the entire Planet.
PolyFit (2).sm (46,79 KiB) scaricato 1295 volta(e).
#31 Pubblicato: 12/12/2019 15:12:19
Hi. This is in case you want to interpolate with an horizontal line.
PolyFit.sm (159,33 KiB) scaricato 1316 volta(e).
PolyFit.pdf (748,27 KiB) scaricato 817 volta(e).
sergio 12/12/2019 16:12:00
#32 Pubblicato: 12/12/2019 15:15:52
NDTM Amarasekera
NDTM Amarasekera
Thank you, Alvaro.
