X-Y Plot for electrical resistance - Trying to plot electrical resistance - Messaggi
Try to eliminate or add them in the input data.
It is to avoid them being used in plot.
Or to avoid conflict between unit-ed numbers and not unit-ed.
When you use Rx in your function, it can't be EEL_par with 1 ohm.
Plot try to use Rx as an number not a unit added number.
You either add unit to Rx or do opposite.
Opposite is eliminating all units of other variables.
Also, how is it possible to only plot (or "stem" as it is called in Matlab ) integer values?
WroteThanks, this makes total sense.
Maybe I chose a wrong word to describe it, shall edit.
It will plot not only integers, numbers actually.
But plot expect them to be dimensionless.
Not just X-Y plot, built-in 2D plot also.
WroteOr if you will really need units;
Plot try to use Rx as an integer not a unit added number.
So how did you add the Ohm symbol under the plot? It won't let me add a unit there.
WroteSo how did you add the Ohm symbol under the plot? It won't let me add a unit there.
1 - Hit multiply after Rx;
2 - (Type W in place holder, place Ctrl+G) or (Click ohm from right pane);
3 - Placeholder shall appear, either double click or press tab to insert Ω as unit.
If you are not typing units after numbers, this is the way.
You can also type ' between step1 and step2.
Units can be typed or chosed with this way more quick.
This will directly open placeholder scroll menu.
WroteAlso, how is it possible to only plot (or "stem" as it is called in Matlab ) integer values?
Altitude is plotted integers.
Solve INVERSE Recursive NASA.sm (13,76 KiB) scaricato 1195 volta(e).
I don't know if there is a stem equivalent for smath plots.
But you can create your own function for that purpose.
stem.sm (8,62 KiB) scaricato 1234 volta(e).
Here, integers are the X direction.
Eventually, easy for the Y direction as applicable.
2D Util Stem ANIM Laplace Diffusion.sm (21,6 KiB) scaricato 1283 volta(e).
You will have to dispose their position by hand.
2D Plot Setup Glyphes.sm (28,77 KiB) scaricato 1166 volta(e).
