X-Y Plot for electrical resistance
X-Y Plot for electrical resistance - Trying to plot electrical resistance - Messaggi
#1 Pubblicato: 16/10/2021 18:56:17
Fabian
Fabian
0 apprezzamenti in 3 post.
I am trying to plot electrical resistance using Electrical Engineering Library and X-Y-Plots Plugins but it does not seem to work:
Can anyone help me plot this?
#2 Pubblicato: 16/10/2021 19:41:28
Gruppo: Moderator
Delete the ohm unit in Rp.
Usually you shouldn't use units while plotting.
For information, this includes most numeric solver functions too.
#3 Pubblicato: 16/10/2021 19:46:20
Gruppo: Moderator
Or if you will really need units;
Try to eliminate or add them in the input data.
It is to avoid them being used in plot.
Or to avoid conflict between unit-ed numbers and not unit-ed.
When you use Rx in your function, it can't be EEL_par with 1 ohm.
Plot try to use Rx as an number not a unit added number.
You either add unit to Rx or do opposite.
Opposite is eliminating all units of other variables.
#4 Pubblicato: 17/10/2021 13:03:39
Fabian
Fabian
Thanks, this makes total sense.
Also, how is it possible to only plot (or "stem" as it is called in Matlab ) integer values?
#5 Pubblicato: 17/10/2021 14:28:23
Gruppo: Moderator
Maybe I chose a wrong word to describe it, shall edit.
It will plot not only integers, numbers actually.
But plot expect them to be dimensionless.
Not just X-Y plot, built-in 2D plot also.
#6 Pubblicato: 17/10/2021 16:08:04
Fabian
Fabian
Plot try to use Rx as an integer not a unit added number.
So how did you add the Ohm symbol under the plot? It won't let me add a unit there.
#7 Pubblicato: 17/10/2021 16:23:47
Gruppo: Moderator
1 - Hit multiply after Rx;
2 - (Type W in place holder, place Ctrl+G) or (Click ohm from right pane);
3 - Placeholder shall appear, either double click or press tab to insert Ω as unit.
If you are not typing units after numbers, this is the way.
You can also type ' between step1 and step2.
Units can be typed or chosed with this way more quick.
This will directly open placeholder scroll menu.
#8 Pubblicato: 18/10/2021 07:03:57
Altitude is plotted integers.
Solve INVERSE Recursive NASA.sm (13,76 KiB) scaricato 1195 volta(e).
#9 Pubblicato: 18/10/2021 09:30:30
... refreshed version ½ timing.
Solve INVERSE Recursive NASA.sm (16,45 KiB) scaricato 1190 volta(e).
#10 Pubblicato: 18/10/2021 17:05:53
Gruppo: Moderator
I don't know if there is a stem equivalent for smath plots.
But you can create your own function for that purpose.
stem.sm (8,62 KiB) scaricato 1234 volta(e).
#11 Pubblicato: 18/10/2021 21:03:39
... you can animate the stem system, have symbols too.
Here, integers are the X direction.
Eventually, easy for the Y direction as applicable.
2D Util Stem ANIM Laplace Diffusion.sm (21,6 KiB) scaricato 1283 volta(e).
#12 Pubblicato: 19/10/2021 00:42:00
Hi. In addition to the overlord solution, this is another approach.
stem.sm (12,15 KiB) scaricato 1200 volta(e).
#13 Pubblicato: 19/10/2021 10:20:17
You can highlight some particular point(s) with glyphe(s) of you choice.
You will have to dispose their position by hand.
2D Plot Setup Glyphes.sm (28,77 KiB) scaricato 1166 volta(e).
#14 Pubblicato: 19/10/2021 11:19:27
Gruppo: Moderator
...In addition to the overlord solution...
Mine was not a solution to be honest.
Just a quick and ugly way to show it is possible.
This is a good solution though.
