Units and matrices
Units and matrices - Messaggi
#1 Pubblicato: 14/07/2010 15:02:00
Edward Ulle
Edward Ulle
21 apprezzamenti in 182 post.
Gruppo: Moderator
I was curious to see how units would be handled in matrices. So I tried a few things and was suprised how well it worked. See screen shot below.
Great job. Well thought out. Remeber everthing is calculated in SI units but comes out fine in US/Imperial units.
Ed
#2 Pubblicato: 24/10/2010 12:11:53
Edward Ulle
Edward Ulle
Gruppo: Moderator
Another advantage of SMath over Mathcad is for matrix elements to have any units and the math is performed correctly. This matrix and multiplication of its elements is not possible in Mathcad.
Ed
#3 Pubblicato: 30/08/2012 02:36:03
ralfsnell
ralfsnell
0 apprezzamenti in 3 post.
How do these US units work?
If I take a simple force in kips multiplied by a moment arm in ft
I get result in J....then when I try to change units to kip ft
by adding kip, I get m kip...then when trying to get to kip ft
I get
kgm^2 kip'ft
________________
(s^2)kip'ft
Following from cut and paste....
el(F,1)*el(A,2)=225.97*{'kg*'m^2}/{'s^2*''kipft}@''kipft
Also, how do you get the units outside the matrix? I can only
put units immediately after the cell values.
Thanks for any responses.
#4 Pubblicato: 30/08/2012 06:58:49
Gruppo: Moderator
Hi ralfsnell,
simply type in the right placeholder
'kip*'ft
regards,
w3b5urf3r
#5 Pubblicato: 31/08/2012 11:04:14
ralfsnell
ralfsnell
Thank you, was trying not to type but rather use the drop-down to insert units.
It appears the "*" was the missing element to that effort.
Appreciate your input and the attachment.
Hi ralfsnell,
'kip*'ft
regards,
w3b5urf3r
#6 Pubblicato: 18/01/2017 18:45:25
justhumm
justhumm
0 apprezzamenti in 18 post.
When using a matrix with elements of a variety of units, is there a way to control the display of the resulting units (imperial instead of SI units)?
For instance, in the attached image:
k'(1,1) = A(in^2)*E(ksi)/L(in) = kip/inch, but results are in kg/s^2
k'(3,2) = 6 * E(ksi) * I(in^4) / L^2(in^2) = kip, but results are in kg*m/s^2
#7 Pubblicato: 18/01/2017 19:57:29
Gruppo: Moderator
Hello [userlink]justhumm[/userlink],
You can try using
OutputUnitsSystem=Imperial
instead of
OutputUnitsSystem=Metric
in
%APPDATA%\Smath\settings.inf
(it is an experimental feature)
frapuano 19/01/2017 06:13:00, justhumm 18/01/2017 20:44:00
#8 Pubblicato: 18/01/2017 20:51:58
justhumm
justhumm
Davide Carpi:
Thanks for the response! It seems to be working.
Wishlist item:
It would be nice to have the ability to switch between feet and inches for the default imperial unit. :-)
#9 Pubblicato: 19/01/2017 09:19:54
Gruppo: Moderator
You're welcome
Wishlist item:
You can join the [SS-1]
#10 Pubblicato: 14/02/2022 18:54:54
Mark R Harris
Mark R Harris
5 apprezzamenti in 90 post.
When using matrices with units the results are given MKS rather than in the input units as shown here:
Units with Matrices
What an I needing to do to show the correct units?
#11 Pubblicato: 14/02/2022 20:46:07
Gruppo: Moderator
- After you calculate and get the result, click on the expression or move your cursor with keyboard to it (Step 1)
- There should appear a placeholder on the result part, write there your desired output unit (Step 2)
- When you press enter or click outside or just loose the focus for expression, your output shall be in your input units (Step 3)
#12 Pubblicato: 14/02/2022 22:06:05
Mark R Harris
Mark R Harris
Thank you so much Overload, greatly appreciated.
#13 Pubblicato: 14/02/2022 23:08:20
Mark R Harris
Mark R Harris
This is getting so close!
I've tried the plus-minus function, but can't get the min or max element values. I suspect this is because the result isn't a maxtrix:
edit by mod: please use the forum attachment feature; images stored outside the domain soon or leater expires or are removed and the topic becomes unreadable. Thank you.
Or it could be my 'PBCAK' (OSI layer-8) problem...
#14 Pubblicato: 15/02/2022 07:47:55
Gruppo: Moderator
That's the cause, yes. You can use sys2mat() function from custom functions plugin or Max()/Min() functions (uppercase M) from the same extension.
#15 Pubblicato: 15/02/2022 15:46:33
Mark R Harris
Mark R Harris
Greatly appreciated Davide. Thank you.
#16 Pubblicato: 16/02/2022 13:40:53
#17 Pubblicato: 16/02/2022 13:50:49
Mark R Harris
Mark R Harris
Thank you Jean, that is very elegant. What was the function of the red kOHMS:=1?
#18 Pubblicato: 16/02/2022 13:56:11
min("matrix") - Returns the smallest element of vector or matrix. If any value is complex, returns min(Re(...)) + i*min(Im(...)).
... Exemplified
2D Plot Discontinuous [min(,)].sm (44,8 KiB) scaricato 1517 volta(e).
#19 Pubblicato: 16/02/2022 14:28:13
Gruppo: Moderator
Actually it is not elegant, very primitive method only used by Jean.
He just continues to try to confuse new users.
He make his own units, not compatible with ISO units.
Which is the case here, he assigned a new red colored Ω to 1. (Ω:=1)
That red Ω is not V/A, ask him to divide it to volts. He won't get 1/Amper.
Don't use his methods, them are just bad practices.
Oscar Campo 11/03/2022 22:52:00, Jason McCool 23/02/2022 18:31:00
#20 Pubblicato: 16/02/2022 15:05:33
Gruppo: Moderator
Jean's math is unitless crusade is garbage.
We don't only do pure math calculations.
Engineering and science needs units.
As I have said before;
Math is unitless, science/engineering is not.
Jean's "silence unit" crap is useless, confusing.
As it is shown below.
Oscar Campo 11/03/2022 22:51:00, Jason McCool 23/02/2022 18:30:00
