Engineering evaluation
Engineering evaluation - need for better graphing ... - Messaggi
#1 Pubblicato: 30/11/2015 13:20:40
Teacher
Teacher
1 apprezzamenti in 20 post.
Hi there,
I'm an mechanical engineer dealing with many different design layout problems.
Request #1:
A I often have to do is displaying internal force systems alont a part. Though the given functions are just piecewise defined and the trailing variable is starting every time new.
Up to now I do the graphing "by hand" in just defining the results point to point .... Woould be nice to get a more easier way to do so ...
Request #2:
Is'nt it possible to intergate the XY-Plot plugin and enhance it a little bit in
- giving it a more friendly GUI for modifying the way of displaying the results
- giving it the possibility to draw an vector-array (4xn) like
(V1x.start, V1y.start, V1x.end, V1y.end
V2x.start, V2y.start, V2x.end, V2y.end
Request #3:
Sometimes I need to display 3D-Surfaces and Vectors. The scope of doing so in SMath are very litte, so it would be great to improve it!
Hope that I'm not the only one who is in need of those things ...
#2 Pubblicato: 30/11/2015 17:06:32
Ernesto
Ernesto
13 apprezzamenti in 74 post.
For Request 1,
Have you tried creating a piecewise function, and later plotting that?
#3 Pubblicato: 23/12/2015 14:44:02
_____________________________
Posting your work sheet is almost garantee to get reply.
Get inspired from the attached.
Utilities Matrix Treasury [Rotate].sm (48,29 KiB) scaricato 1351 volta(e).
Utilities [Plot points on Trace].sm (13,08 KiB) scaricato 1406 volta(e).
Integrate Discontinuous.sm (24,9 KiB) scaricato 1490 volta(e).
Utilities XY plot.sm (16,5 KiB) scaricato 1536 volta(e).
LGC Logistic.sm (37,77 KiB) scaricato 1559 volta(e).
Utilities Quick f plot.sm (41,66 KiB) scaricato 1584 volta(e).
Contour X_Y plot.sm (55,83 KiB) scaricato 1520 volta(e).
Contour X_Y plot [More Parametric].sm (101,88 KiB) scaricato 1374 volta(e).
ioan92 23/12/2015 14:51:00, Radovan Omorjan 23/12/2015 17:37:00, Andrey Ivashov 14/01/2016 12:52:00
#4 Pubblicato: 12/01/2016 13:39:32
Teacher
Teacher
Hi there,
sorry, forgot to add example.
Here we go. Its about constructing a lever of an container vehicle.
On page 3 there are two "Bereiche" where there are different functions for the bending gear Mb and below that there is a Diagramm...
Container Vehicle.doc (768,5 KiB) scaricato 975 volta(e).
calculations.sm (844,92 KiB) scaricato 1572 volta(e).
#5 Pubblicato: 13/01/2016 13:09:57
Ernesto
Ernesto
There are only 2 pages to this document, there is no page 3. please repost
#6 Pubblicato: 09/04/2016 18:20:44
Teacher
Teacher
Hi, sorry I just posted the tasks not the calculations .... So I've done that now in the addition to the post abovs.
