Visible or not visible component
Visible or not visible component - Visibility of a component depends on the result of the logical function. - Messaggi
#1 Pubblicato: 10/05/2017 09:40:04
Janusz
Janusz
0 apprezzamenti in 6 post.
I propose to add the new feature: a component is visible or not visible. It should depend on, for ex., result of the function "if". If calculation_type=1 then (dw is visible) and (gw is not visible) else ... This option will allow to make the display of the data elements dependent on the type of the calculation element. p.s. Very nice and useful software!
#2 Pubblicato: 10/05/2017 13:49:55
The way I interpret you demand is like:
conditional compute/not compute.
In some way we have that already.
How to code invisible ? Hello Gurus !
Visible.sm (12,18 KiB) scaricato 1538 volta(e).
#3 Pubblicato: 11/05/2017 16:00:41
Arie
Arie
94 apprezzamenti in 285 post.
I think this exists as a plugin. Check out conditionally formatted labels plugin. More info here: http://en.smath.info/forum/yaf_postst2100_Conditionally-Formatted-Labels.aspx
Davide Carpi 12/05/2017 06:32:00
#4 Pubblicato: 11/05/2017 20:33:29
Ah ! The forum has crashed for me.
Can't see all previous messages [Martin, Davide ...]
Image Spot True_False.sm (31,61 KiB) scaricato 1586 volta(e).
#5 Pubblicato: 11/05/2017 23:12:01
... added simpler spot, neat.
Image Spot True_False.sm (47,12 KiB) scaricato 1516 volta(e).
#6 Pubblicato: 12/05/2017 11:12:33
Hello Janusz,
Please, give more hint of what you wish. Previous replies vanished in the wind.
By default, some component(s) don't compute.
"Pixels not in the Map are black because undefined elements matrix are zero by default".
If it works for you: increase "kmax, kkmax" [my 1.6GHz very slow].
Pattern Cahos 4150 [RGB].sm (94,69 KiB) scaricato 1324 volta(e).
#7 Pubblicato: 14/05/2017 15:50:38
Ernesto
Ernesto
13 apprezzamenti in 74 post.
Janusz,
A limited way of doing this is to right click your if statement (or any operation) and deselect "Display input data".
This leaves you with only the result printed out.
#8 Pubblicato: 15/05/2017 06:33:05
The "if/otherwise" is common in Engineering. A less common "if"
is the the "on error", implemented as "try/on error" [6179].
In some other way, it is a "compute/not compute" component(s).
Visit this gorgeous application. 7min [1.6 GHz micro laptop.
Image Rotate RGB.sm (349,66 KiB) scaricato 1576 volta(e).
Few things have changed in the forum ! ?
#9 Pubblicato: 15/05/2017 07:07:43
... compute/not compute can be "bolean" too .
Random fill this Gaussian region.
Random Fill Range PDF.sm (39,45 KiB) scaricato 1520 volta(e).
