1 страниц (9 вхождений)
Visible or not visible component - Visibility of a component depends on the result of the logical function. - Сообщения
I propose to add the new feature: a component is visible or not visible. It should depend on, for ex., result of the function "if". If calculation_type=1 then (dw is visible) and (gw is not visible) else ... This option will allow to make the display of the data elements dependent on the type of the calculation element. p.s. Very nice and useful software!
The way I interpret you demand is like:
conditional compute/not compute.
In some way we have that already.
How to code invisible ? Hello Gurus !
Visible.sm (12,18 КиБ) скачан 1533 раз(а).
I think this exists as a plugin. Check out conditionally formatted labels plugin. More info here: http://en.smath.info/forum/yaf_postst2100_Conditionally-Formatted-Labels.aspx
Davide Carpi 12.05.2017 06:32:00
Ah ! The forum has crashed for me.
Can't see all previous messages [Martin, Davide ...]
Image Spot True_False.sm (31,61 КиБ) скачан 1580 раз(а).
WroteI propose to add the new feature: a component is visible or not visible. It should depend on, for ex., result of the function "if". If calculation_type=1 then (dw is visible) and (gw is not visible) else ... This option will allow to make the display of the data elements dependent on the type of the calculation element. p.s. Very nice and useful software!
Hello Janusz,
Please, give more hint of what you wish. Previous replies vanished in the wind.
By default, some component(s) don't compute.
"Pixels not in the Map are black because undefined elements matrix are zero by default".
If it works for you: increase "kmax, kkmax" [my 1.6GHz very slow].
Pattern Cahos 4150 [RGB].sm (94,69 КиБ) скачан 1318 раз(а).
Janusz,
A limited way of doing this is to right click your if statement (or any operation) and deselect "Display input data".
This leaves you with only the result printed out.
The "if/otherwise" is common in Engineering. A less common "if"
is the the "on error", implemented as "try/on error" [6179].
In some other way, it is a "compute/not compute" component(s).
Visit this gorgeous application. 7min [1.6 GHz micro laptop.
Image Rotate RGB.sm (349,66 КиБ) скачан 1570 раз(а).
Few things have changed in the forum ! ?
... compute/not compute can be "bolean" too .
Random fill this Gaussian region.
Random Fill Range PDF.sm (39,45 КиБ) скачан 1511 раз(а).
