Temperature field
Temperature field - not straight line but one parabola - Messaggi
#1 Pubblicato: 15/07/2023 03:32:54
Valery Ochkov
Valery Ochkov
67 apprezzamenti in 713 post.
I am trying to plot a temperature field in a three layer wall. There is no problem with the outer layers. But there is a problem in the middle layer - there should be a parabola, not a straight line. How to draw this parabola in the simplest way - with one formula. I know the hard way.
Stenka-3-eng.sm (60,64 KiB) scaricato 1407 volta(e).
#2 Pubblicato: 15/07/2023 06:51:42
Laurent Fournier
Laurent Fournier
9 apprezzamenti in 66 post.
There are so many splines and Bezier interpolations in this forum!
But I don't understand why the connecting line has to be a parabola, because inside one wall layer the parameters (conductance, permeability) are constant so you should have only straight lines. Unless you found a way to have a gradual mix of material!!!
#3 Pubblicato: 15/07/2023 06:56:42
Valery Ochkov
Valery Ochkov
In the outer walls, the thermal conductivity does not depend on temperature, but in the middle wall it depends linearly!
#4 Pubblicato: 15/07/2023 07:17:49
Gruppo: Moderator
Don't know if that is the simplest solution.
Stenka-3-eng.sm (58,13 KiB) scaricato 1410 volta(e).
Valery Ochkov 15/07/2023 07:25:00
#5 Pubblicato: 15/07/2023 07:26:46
Valery Ochkov
Valery Ochkov
Fine!
And if the dependence of thermal conductivity on temperature is more complex, obtained, for example, through interpolation of discrete data. I would like to see an integral in the solution!
#6 Pubblicato: 15/07/2023 07:32:04
Gruppo: Moderator
Version with mathcad block to collect the equations
Stenka-3-eng1.sm (59,5 KiB) scaricato 1429 volta(e).
Valery Ochkov 15/07/2023 07:40:00
#7 Pubblicato: 15/07/2023 09:13:21
1. Three layers linear from min(x).
2. NON-linear from experimental
... project done Mathsoft Collaboratory.
Make the first & third segments linear.
The two documents sanity checked Smath Solver 30405.
Maths min(x),max(x).sm (22,23 KiB) scaricato 1424 volta(e).
0Appendix_1 Thermal Insulation.sm (10,24 KiB) scaricato 1395 volta(e).
#8 Pubblicato: 16/07/2023 05:40:21
Valery Ochkov
Valery Ochkov
One solution from Alan Stevens
Stenka-3-Alan.sm (60,35 KiB) scaricato 1382 volta(e).
