SMath is not using the latest version of CoolProp on my PC
SMath is not using the latest version of CoolProp on my PC - Query: How to Update CoolProp for SMath - Messaggi
#1 Pubblicato: 11/11/2025 12:50:49
Gerard Lardner
Gerard Lardner
3 apprezzamenti in 8 post.
SMath on my PC is showing version 6.4.1 but Excel shows the latest (nightly) version 7.1.1. Somehow, despite updating CoolProp to v7.1.0 and then to the nightly 7.1.1, SMath is still using an older version.
The files Coolprop_x32.dll and Coolprop_x64.dll in %USERPROFILE%\AppData\Roaming\SMath\extensions\plugins\ca92ef03-c7da-4888-98ad-528482733e2f\6.4.8214.13502 show the date and time when Coolprop was updated.
SMath is also the latest version, 1.3.0.9126, updated a few weeks/months ago.
- How can I make SMath use the latest installed version of CoolProp?
- Where does the SMath Coolprop Wrapper look for links to the current version of CoolProp?
- And maybe how can I find and safely remove the older versions of CoolProp?
Modificato 11/11/2025 13:06:53
#2 Pubblicato: 13/11/2025 09:05:05
Gruppo: Moderator
the Coolprop_x##.dll libraries are by default the ones provided within the SMath "Extensions Manager" CoolpropWrapper plugin (there is a GitHub version too, but I think it is several iterations behind).
You can try to replace them manually following the instructions here (point 4 of README.md) but it is not guaranteed that the plugin will still works as intended or at all, since the Wrapper wasn't developed nor tested for the new libraries.
#3 Pubblicato: 13/11/2025 10:34:36
Gerard Lardner
Gerard Lardner
Ah, OK. I hadn't understood that. I was simply confused that Excel showed a newer version of CoolProp than SMath (and Maple Flow has another version).
Thank you for the instructions for manually updating CoolProp in SMath. I may not try it, since you say the wrapper is tied to the library version, and the current version of CoolProp is a major version number step from the version in the wrapper.
Modificato 13/11/2025 10:35:20
#4 Pubblicato: 13/11/2025 12:08:17
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
You can try Mathcad Custom Functions plugin
Links:
1. https://sourceforge.net/projects/coolprop/files/CoolProp/nightly/MathcadPrime/
2. https://www.smath.com/ru-RU/forum/topic/DaKGEh/Mathcad-Custom-Functions
Userefi path: %appdata%\SMath\extensions\plugins\91a20d24-c30b-4774-9b1b-4d502a80420f\1.1.8035.3236\userefi
You must copy CoolPropMathcadWrapper.dll there.
Gerard Lardner 08/04/2026 18:11:58
#5 Pubblicato: 14/11/2025 00:12:58
Gerard Lardner
Gerard Lardner
I think I am awfully stupid, but that's not working for me. I downloaded CoolPropMathcadWrapper.dll from the link above and copied it to the userefi folder as indicated. But SMath does not see it; the functions beginning get_fluid_param_string() are not working.
If I use CoolProp_get_fluid_param_string("version"), I still see v6.4.1, but I guess that's using CoolPropWrapper, not CoolPropMathcadWrapper. (As I noted before, Excel returns v7.2.1 for the Coolprop version)
Can you suggest where I might be going wrong?
#6 Pubblicato: 08/04/2026 18:10:25
Gerard Lardner
Gerard Lardner
Final follow-up: I had some problems with my PC, which necessitated uninstalling and reinstalling and upgrading a lot of software. In reinstalling SMath and CoolProp, I followed Uni's instructions above and... it all worked!
If I use the Mathcad Custom functions format ("get_global_param_string("version")), I see the installed version of CoolProp;
if I use the CoolProp wrapper format ("CoolProp_get_global_param_string("version")), I see the older version of CoolProp.
Modificato 08/04/2026 18:11:16
